Question about GoVideo VR3845 DVD Recorder/VCR
DVD made from VHS tape will not work on other DVD players
I made a DVD from a VHS tape, using the Go VIdeo, model #VR3845. The DVD can be played on this machine. However, when I tried to play the DVD copy on another DVD player, it did not play. The different DVD machine would not read the DVD. The machine does not acknowedge that there is anything on the DVD. In the past, I have made many DVDs from VHSs on this Go VIdeo machine and could play the DVD copies on other DVD players. What am I doing wrong?
Helen GurnyMY UNIT IS A 4940, BOUGHT FIVE YEARS AGO, BUT NOT USED TILL RECENTLY.. THE FINISHED DISC ONLY PLAYS ON THE GO VIDEO. MY OTHER PLAYERS SAY, "NO DISC." I USE THE PRESCRIBED DVD BLANK, A DVD-RW. SINCE IT DIDN'T PLAY BACK, I SWITCHED TO A DVD-R, SAME PROBLEM. THE DISC'S HAVE BEEN FINALIZED.. DO THEY MAKE A RECORDER THAT WILL RECORD AND RENDER A COPY THAT WILL PLAYBACK ANY DVD FORMAT AND ON ANY RECENT MODEL PLAYER? I HAVE MORE THAN 1OO TAPES OF FAMILY, FREINDS, VACATIONS, GRANS, ETC, SINCE I BROUGHT MY FIRST RECORDER IN 1983.
  • 495 Answers
Try running a DVD cleaner through it and see what happens. You can get one at Walmart for under $10. If that doesn't do the trick then take it to someone that can open it up to clean it.
Posted on Feb 20, 2009
  • Manoj Rout
    Manoj Rout Feb 20, 2009
    make sure you finalize the disc very important!
  • Manoj Rout
    If cleaning the lens with a CD cleaner was not corrective, perhaps it
    may require manually opening the unit, using a can of compressed air
    and cotton buds to do the internal cleaning. it might also help to
    lubricate the mechanism especially the slider bar.
    Additionally, pls try a reset, this is simply unplugging the unit from
    the mains for an hour or so. Of coursse all settings would revert back
    to factory default.
    Incidentally, the regional locking might have had a glitch. Pls try to
    set the region lock to "free" (all regions). This could be done by:
    • With no disc loaded press SETUP
    • With your GoVideo remote, navigate to the lock icon
      and press "0-0-0-0". A window will appear saying congratulations
      Player(Loader) Region-free. When you see that window appear,
    • Activate Region free by pressing ENTER.
    In some instances, a password may be required. 0000 is the default password to get you in to change the default two letter region code.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
How do you record a VCR tape to a DVD?
Import the video on your pc using something like
http://www.newegg.com/Product/Product.aspx?Item=N82E16815260028&cm_re=av_card-_-15-260-028-_-Product
and convert it to dvd format using the supplied software..
Jan 16, 2010 | GoVideo VR3845 DVD Recorder/VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
VHS to DVD recording
Yes, just turn off the tv.
Walt
Apr 08, 2008 | GoVideo VR3845 DVD Recorder/VCR
Recorded DVDs will not play on other DVD players
Some DVD players have a protection which keeps you from playing copy writed DVD's even if it's on the DVD-R's. Most of the latest DVD players within the past 3-4yrs have this intergraded into it. In that case, your recorder is really working you just need a DVD player that supports your recorded dvd's vs. non-recorded ones.
Have you also tried to play those DVD's on a media center/system on your pc or computer? That might also help you decipher if it's really the burner or the DVD players as well...
Let us know how it goes. Hope this helps..unfortunately when the DVD player has that prevention already intergraded internally there is no way to remove it..its just how it comes.
Apr 02, 2008 | GoVideo VR3845 DVD Recorder/VCR
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
Go Video VR3845 player question
cant play pal on ntsc ok wrong formatt
Feb 04, 2008 | GoVideo VR3845 DVD Recorder/VCR
GoVideo VR3845 DVD Recorder/VCR Logo
112 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
