Question about Bosch Dryers
ERROR Code F18
BOSCH LOGIXX CONDENSER TUMBLE DRYER WTS84516GB.
Stopped Working Giving error code F18
5 Suggested Answers
SOURCE: How do I turn off
We had a similar problem with our Bosch dryer... every now and then when we were using the dryer an alarm would go off and it would stop drying. We checked through the manual and it had no information. Then one day I noticed that there was a flap on the end of the exhaust vent outside the house. As an experiment I propped the flap open so that it never fully closes.  Now we never have the problem with the dryer. I suspect what was happening was that as the dryer was reaching the end of the drying cycle it was pumping out less and less exhaust to the point where it was too weak to open the vent flap, and the build up of exhaust in the ductwork triggered the alarm. I don't know if that's what's causing the alarm with your dryer but its worth checking.
Posted on Dec 14, 2008
huuum
  • 750 Answers
SOURCE: I have a bosch classic
Hi ya,
Welcome to fixya.
You have a bad filter sensor and or relay !
In a Bosch this is not a usual do it your selfer. You need a hands on experienced tech.
Please leave a solved rating before you sign off!
Huuum
Posted on Jan 23, 2009
  • 414 Answers
SOURCE: have a Bosch logixx condenser dryer. key sign on screen
You have activated the child lock, basically you have held the start button for over 3 secs. turn the dryer to the cycle you want and keep your finger on ther start button to deactivate. If this doesn't work you may have a module problem. Double check your manual for child lock info. if no module go to link and enter you Enr number.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Jul 07, 2010
SOURCE: water tank full (!) in bosch tumble dryer WTE86301gr
As a matter of fact I have solved the problem. The dryer is now fully functioning again. :-)
I'll try to explain how to fix the problem:
The water that condenses in the condensor (doh!) drips down into a container situated below the condensor. The moist air that passes through the condensor is the same air that circulates via the clothes, thus it also contains some lint that the filter doesn't catch. Over time there will be some build-up of lint and mucus (?), clogging the tank AND a sensor that sends a signal to the electronics to start the pump that evacuates the condensed water to the removable tank in the upper part of the machine. This messes up the function of the water evacuation system.
Alright, pull out the condensor and find a hatch in the 'floor' in the farther part of the compartment. Below the hatch you'll find the container that collects the condensed water. Start by cleaning it as thoroughly as you can. There are a few 'nooks and crannies', take your time, also flush with some fresh water and maybe some gentle cleanser to get rid of the mucus. The pump and the sensor for the pump are located in the left part (viewing from front of the machine) of the container. Try to flush there as well.
If this procedure doesn't solve the problem you'll have to disassemble the machine to also be able to remove the pump and sensor housing. I had to do this on mine. Quite a few screws to remove and keep track of, but pretty straight forward if aren't too uncomfortable with 'fixing things'.
I have some pictures of the 'project' somewhere, let me know if you would like to see them or if I may help you some other way.
BR /Hans
Posted on Aug 09, 2011
SOURCE: Our Bosch Classixx Condenser Tumble Dryer works
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Posted on Oct 24, 2011
Bosch condenser tumble dryer, stopped spinning
Could be due to a stretched or broken belt
Jun 24, 2016 | Bosch Dryers
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
    Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
    I have the model service manual though HERE
    Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
    Tumble dryer manuals
    http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
    When you open the link, half way down the page you'll see the following, "click here to download instruction manuals (launches in a new window)"
    When the new window opens, type in "WTA3606GB" in the search box and press<GO>
    The manual will be in a pdf document format. You can download it or open it and then save it- the site is free.
    Dec 04, 2013 | Dryers
    Have a Bosch logixx condenser dryer. key sign on screen
    Jul 02, 2010 | Bosch Dryers
    How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
    how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
    Jan 19, 2010 | Whirlpool Dryers
    How do I turn off the alarm on our Bosch tumble dryer, it's a Bosch Logixx
    Aug 23, 2008 | Bosch Dryers
    Dryers Logo
    85 people viewed this question
    Top Bosch Dryers Experts
    Lawrence Oravetz
    MightyMikeJr
    Are you a Bosch Dryer Expert? Answer questions, earn points and help others
