Question about Nokia 3230
How can format the phone memmory of NOKIA 3230
I tried with *#7370#, but asking lock code,i dont know the lock code.
please help.
Tell me formate code of nokia 3230 and password
Posted on Jul 09, 2010
    Scholar:
  • 135 Answers
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Posted on Feb 23, 2009
I forget my phn code of n72. And i want to format my phone. My memory card is courapted now what i should do. I forget my memory card pasword plz help me.
HI, U CAN UNLOCK YOUR PHONE. FOLLOW THE INSTRUCTIONS-----1) DON'T TURN OFF THE PHONE 2)REMOVE MEMMORYCARD FROM LOCKED PHONE AND PUT IN AN MEMMORY CARD READER. CREATE DIRECTORY E:\SYSTEM\RECOGS AND COPY THC-NOKIA-UNLOCK.MDL INTO THIS DIRECTLY...... ORYLY 3)REMOVE MEMMORYCARD AND PLASED IT INTO LOCKED PHONE...THE THC-NOKIA-UNLOCK-PROGRAM WILL START AFTER 120 SECONDS 4)REMOVE BATTERY AND MEMMORY CARD .PUT BATTERY BACK AND RESTART ...THE PHONE LOCK IS RESET TO 12345.TO FORMAT YOUR PHONE USE THE CODE *#7370#.MEMMORY CARD CAN BE FORMATTED BYU SING THE CODE *#7780#..THANKS
Nov 18, 2010 | Nokia N72 Cellular Phone
Dear sir, i forgot my wallet code so plese help me my hendset nokia 3230
If you forgot wallet code for Nokia 3230 phone,please use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Thank You
Aug 11, 2010 | Nokia 3230
My camera doesnt want to work.. it says features not supported my phone is nokia 3230 but i dont know the code for original phone settings i try to format the phone but still it didnt work pls help me...
Tray code 12345.But Its hardware problem,formatting will be useless.to fix it only change your camera modul or flexyble cable.100% works.I hope it help.
Feb 26, 2010 | Nokia 3230
Formatting code for Phone Memory
trensfer all phone memory to Memory card and then try receive data this should work.
Jul 24, 2009 | Nokia 3230
Formating code for phone memory
try this procedure.. password less procedure
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
Jul 09, 2009 | Nokia 3230
How can format n70 phonememmory(not memmory card)
Scan the memory with latest antivirus. Download R-Studio with its serial. R-studio is an extraction tool. Extract all the files in your memory. And format the memory. Copy the files again in your phone memory
Mar 02, 2009 | Nokia 3230
My nokia n72 has got locked and is asking for lock code wen switched on . please help
kaja,
try to key in *#7370#12345 ( add 12345 if you didn't chage your security code)
note: if you put security code to your phone cahnge 12345 using your security code
cheers,
mark
Jan 17, 2009 | Nokia N72 Cellular Phone
Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Aug 28, 2008 | Nokia 7610
Battery gets discharged
Possible Problems:
1. Maybe there's a virus.
2. Often restart can drain the battery.
Possible Solution:
Format it by pressing the green key or call key + no. 3 + asterisk(*) at the same time. But 1stly, turn off ur fone, then b4 the NOKIA logo appears, hold these following keys altogether. You will see the "Formatting" word afterwards..
OR...
Format it by typing *#7370.
Aug 03, 2008 | Nokia 3230 Cellular Phone
Hi Sonubaath
press *# 7370 # your phone will format.....
Jul 30, 2008 | Nokia 3230 Cellular Phone
Nokia 3230 Logo
552 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
