Question about Fujitsu Siemens AMILO Pro V7010 Notebook
Fujitsui seamans wireless switch
I cant get access to wireless on my lap top is there a switch that needs to be turned on
    President:
  • 1,223 Answers
It should be like tower sign or dish antenna like sign u should know the config of the laptop what are the components if it has wifi then sure there is key for that on keyboard may be on the Function keys
Posted on Feb 20, 2009
Cant connect to the internet on my lap top
There are several things you need to check:
Have you been able to connect in the past? If so, what has changed. If it is the recent past, do a system restore back to when it worked.
Is the access point working? In other words, is there a wireless network nearby to connect to?
Is your wireless adapter turned on--on the computer? Many times people inadvertently turn the adapter off. It's most likely turned on with a Fn-special function key combo. Some computers have an actual switch.
If you have a wireless adapter turned on and you can see a wireless connection, then all you should need to do is tell the computer to connect and give the proper pass code.
Aug 10, 2011 | Toshiba Satellite Pro L300 Notebook
Cant switch off wired connection to wireless
Since I do not know what router your using go to the web page I believe it is 192.168.0.1 or 192.168.1.1 this will bring you to your routers page then you can go to the wireless section and disable it. Also if you are using a wireless connection that you can manage with a switch process such as those on lap tops you can turn those switches off as well. Thanks for using FixYa! Do not forget to place a good vote for me as well John
Apr 02, 2011 | Computers & Internet
I am not able to connect through internal wifi(wireless) network device in my Toshiba Satellite L505D Laptop. I am able to connect net through a external USB wireless network adapter.What is the problem...
Locate the wireless switch and turn it on? if it is on you might need to reset the modem from your service provider. Just go and hit the reset button on the modem or turn it off completely. Power it up again and make sure that the switch is turned on if you have one for this lap top some are automatic.
The switch is usually located on the left or right front of the lap top housing in the front or on the keypad. You may have to push the FN key if the key is blue highlighted. Hit FN and press the wireless key if applicable. Make sure all is on and switched then reset the wireless modem or connection.
Jan 28, 2011 | Toshiba Satellite L505DGS6000 Notebook
Lap top will not conect to the wireless internet connection
If you are on a laptop: (windows)
1. check to make sure your physical on off switch for the wireless card is turned on. Windows will sometimes still show it as being active while the switch is physically still off.
2. Disable/re inable the software connection to the wi fi
(MAC) Disable reinable the wireless card in dropdown menu
3. restart the wi fi router
Jan 16, 2011 | WiFlyer - Portable, shareable WiFi base...
I just purchased a new lap top. i have net gear 123for my tower. cannot seem to get the lap top to work. it keeps asking for a security code. Do not know what it is
no we cant know what it is, it needs to be connected via the cable first, then access the router's setup and change the wireless security key.
sometimes the security key is printed on the back of the router
Jun 05, 2010 | NetGear RangeMax WPN824 Wireless Router...
I have a D-link wireless router and I can't get my lap top to find the wireless network? Can you help me get it working? My lap top is saying that I need to turn on my wireless capability and I don't know...
Check your laptops manual. There will be a switch on your laptop that will allow you to turn your wireless card on and off. Depending on the model of your laptop there will either be a function key combination or a slider switch. If you need more help then please post the make and model of your laptop with any followup questions you may have.
Feb 01, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Acer computer
you have to switch on your laptop wifi
Oct 28, 2008 | Acer Computers & Internet
I have lost connection with my wireless
I have gigaset siemens SE568 modem i call siemens company to get password so
that nobody can access into my wireless the problem now i can't access to the internet through
my lap-top i tried so many times i put the same security passphrase but no use now i don't want
to enable password i want to disable it cause i need to use the internet though my lap-top
as wireless please help me
Sep 11, 2008 | Belkin Computers & Internet
How to turn on wireless on Acer Aspire 4520 laptop
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Sep 04, 2008 | Computers & Internet
Lap top wont connect via wireless router. verizon says NEED TO TURN ON WIFI BUTTON'. CANT FIND A WIFI BUTTON -HELP
lokk at the bottom right hand corner of your screen for a wireless signal/then right click/view available signal/click on yours and make sure its ENABLED or look for your wireless switch on your model laptop/ if your are not sure go to the maker website/go to support/driver download/your model/then specs and it will tell you where that switch is
Aug 29, 2008 | Gateway Computers & Internet
Computers & Internet Logo
340 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
