Question about HP 530 Notebook PC
My hp530 laptop shows blue screen then it restarts when i try to install win xp it tells me that setup did not detect harddisk
  • 17 Answers
Hi, if you are using a SATA drive there maybe a setting in your bios to let the laptop know which drive you are using.(or you may need third party software from the drive manufacturer) if you are using an IDE drive i would check it integrity first by scanning or use a known good drive to test.Also try removing and reseating your ram.
hope this helps
Posted on Feb 20, 2009
My PC-GP1-C7M laptop getting restarted during windows start with blue screen
you should delete the system partition and then set it back again without deleting the other partitions (with data) of course, then format it normal not quick then continue installing your win xp 3.
May 19, 2012 | Computers & Internet
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
Insataling windows xp problms
If u just want XP . Source a dos boot ( u can get files from internet), format the HDD .create main partision for windows xp and try installing
May 22, 2009 | Computers & Internet
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Having Problem formating a hard drive with P4M900-M7 FE board
It sounds like the hard drive is bad, it should not take anywhere near that long to format it. The blue screen that you are getting trying to load xp can also be caused by the hard drive being bad, because it cannot read the information to complete the boot up.
If you have another hard drive sitting around, throw it in and try to install windows on it.
Hope this helps
May 02, 2009 | Biostar P4M890-M7 Motherboard
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Installation failure- HDD not detected
may be your harddisk is not detected.
check in bios settings.
and disable sata otion .then try.
Dec 29, 2008 | HP 530 Notebook PC
Missing Operating System error
your bought compag computer is a new one , because that error is appears only if the hard drive or the harddisk is defective or damage. Your installation of windows xp is finished totally because sometimes the error is appears because the system installation is not finished and the os system cannot read. try to re install again the windows and delete the old partitions and create again if the problem is the same even there is no error in the installation until it's finished i say that the problem is in the harddisk. Maybe the harddisk develop a bad sector in the master boot record of the hardrive
Apr 15, 2008 | Compaq Presario 700 470024-192 Notebook
HP 530 Notebook PC Logo
538 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
