Question about HP LaserJet 2420 Printer
Printer gives faint print
New fuser intalled
toner replaced
There is scaner assembally problem claen it or send sirvice center
Posted on May 26, 2009
    Genius:
  • 2,120 Answers
Is Eco-mode turned on?
Posted on Feb 21, 2009
Printing very light Okionly B410d printer usesblack toner cartridge
Try performing a stop test. Send a test page and turn it off mid print. Retrieve the page from the printer to see if the image is readable before it went through the fuser. If so the the fuser may need to be replaced.
Jan 16, 2014 | Oki Electric Industry C3300n Laser Printer
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
Samsung CLX-3175FN printer only prints VERY faint image. Just replaced all toners with genuine Samsung. Never had this problem. All contacts look clean???
Faint prints with Laser Printer usually occurs when the drum is full with the wasted ink (toner power) or when the Fuser Unit is not working correctly. First of all try cleaning the Drum and remove the wasted toner power. There should be an opening on one of the end of the drum. In some cases, it needs to be disassembled to remove the wasted inks.
Also remove the fuser unit and clean the unit. Please handle it with care and never clean it when it's hot/warm. Only do this, after the printer is left turned off for about half an hour.
If nothing is helpful, try with another/new drum or fuser, that will help you get to find out the exact cause of the problem.
Good Luck.
Thanks for using FixYa.
Sep 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly...
Have you checked the fuser?
A laser printer fuser assembly is the heating roller unit that melts and fuses the toner onto the paper. The fuser assembly is made up of a heating roller and a pressure roller.
The heating roller applies the heat to the toner on the printed page and the pressure roller presses and fuses the toner into the printed page. If it's bad and not heating properly, the print will be faint, which is what you describe. You may be able to remove and clean the fuser, but if the printer gets lots of use, it may just be worn out.
See this link for an idea of what it looks like and a price.
http://www.fastprinters.com/ProductDetails.asp?product_id=DELL-H4919
I do not work or represent this company, so shop around.
Mar 22, 2010 | Dell 1700n Laser Printer
When printing, half the page is very faint and almost unreadable. The rest is fine.
This can be a bad toner cartridge or a bad fuser. Replacing the toner is an easy test, but the fuser if you need it will be expensive.
Mar 09, 2010 | Samsung CLP 300 Laser Printer
Printing too lightly
Is the paper hot when you take it off the printer? The reason I am asking is, there is a part called a fuser, its the last process in the printing cycle. The fuser gets to almost 300 degrees to melt the toner onto the paper. If the fuser is not working correctly then the paper will be room temp and their will be no print.
Apr 04, 2009 | Brother MFC 8220 All-In-One Laser Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Faint printing quality
the problem isn't with the toner. you have to check the fuser unit
Oct 16, 2008 | Samsung ML 1510 Laser Printer
Faint printing
I have installed brand new toners that were bad. Fortunatly it was at work so I didnt have to personally purchase a second one to find out. But it does happen, espically with reconditioned toners or off brand toners
Jul 03, 2007 | Samsung ML 2010 Laser Printer
Faint mirror image when printing
It's most likely one of 2 problems...the toner cartridge or the fuser. The toner cartridge transfer roller may still be charged and keeping a little bit of the previous page's information on it, to be transferred on the next sheet. I would try a different toner cartridge first to see if that solves it.
Jun 18, 2007 | Tally T8006 Laser Printer
HP LaserJet 2420 Printer Logo
220 people viewed this question
Seeker5211
Seeker5211
