Question about ASUS A8N-SLI Deluxe Motherboard
I replaced the heatsink fan it booted up like three times.tryed put load xp wouldnt boot up from cd rom.Iset boot priority to cdrom.I tryed to reset jumper took out bat all night.the first time it booted up i had to take out the board & put it back to boot the 2nd time. the same thing for it to boot agin it whent to bios.Not sure if I change some thing there that might be the problem.Now when it starts the keyboard number lock does not light.What the hell could it be?It worked just fine before I change that fan?Please help if you can Rob.
  • bigguy1967 Feb 20, 2009
    I put a zalman on didaway with the fan.Its not the cpu fan.
  • 285 Answers
Well, first you should check wether the fan actually starts when you turn on the pc. If it doesnt your cpu will be overheated in no-time, causing the pc to reboot. That fan then probably has the wrong voltage, or requires to much power, which your power supply may not be able to provide.
If it works, you should try to find out how powerful this fan is, meaning how much air it moves per minute. If this fan is less powerful than the previous one, your cpu will be overheated.
If neither of these solutions apply, I guess you should contact your vendor and request replacement. It may be just the fan that's broken.
Posted on Feb 20, 2009
  • Yannick Verhoog Feb 21, 2009
    Oh well I'm sorry for the misunderstanding then.
    I'm just new here myself, so I don't have that much experience yet.
    Which fan is this about then?
The evo n610c will not boot right. when i install the windows xp to it some how it more likely freeze or auto shut off due to overheat. now i try to clean the fan but not works right. so in this case is...
If you have an over heating issue then wasting ur time loading any operating is just that a waste. No u can not load an OS from an ipod. u have to load it from an external CDROM. Some of the newer mini's will boot from a flash drive but then you have to make the flash drive a "bootable device" not something a novice user wants to mess with. If u want to tare it down this far you can check the heatsink is firmly on the cpu. Make sure the exhaust fan is even working too. I wouldnt put alot of time or money in that evo with the prices of laptops being pretty reachable right now.
Jun 23, 2010 | Compaq Evo N610C Notebook
I purchased a compaq M 300 laptop without a hard-drive,and CD-Rom. Now I would like to install Windows XP using a hp MB cradle I recently purchased but the unit is not reading the WinXp cd-rom. How can I...
u have to bootable disk of win xp.then set first boot devicce in bios your dvd rom or cd rom.
then u get message pres any key to boot from cd .wehn u start the ssytem.
then follow the procedure.
press enter.
then create parttion.
as u like.
thejn simple follow the procedure.
Oct 11, 2008 | HP Computers & Internet
I have a Gateway 507 GR Windows XP Home Edition. Windows does not load/Boot, Error message "Not found or corupt. I can hit I think it is F-2 or F-12 (I forget) and go to the BIOS settings, and try and...
to go to bios setting either u can hit F2 or F1 key. then u change the boot priority. set it to cd-rom device.
after that u can boot from any bootable cd.
for your operating system problem, boot from the xp bootable cd after setting boot priority, and then repair or reinstall your operating system. some files might have been corrupted.
Mar 01, 2010 | Gateway 507GR PC Desktop
Dell Optiplex GX270 will not boot from disk
Does it show
boot from cdrom?
did you answer (Y)
then hit spacebar?
have the bios set to boot from cdrom/first boot device cd-rom?
If any of these settings are not applyed you will not restore xp on your computer
go into bios and conferm settings
first boot device if set as floppy or hard drive change to cdrom
on some systems you can hit the (f12) key to bring up a boot window and select the cdrom and boot from there then it will ask the normal questions
Dec 03, 2009 | Dell Optiplex GX270
Boot up
Hi there.
Try clearing the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted. If there is no jumper remove the battery for an hour and make sure the power cord is removed from the back before you clear the cmos
Good luck and thanks for using Fixya!!
Feb 18, 2009 | ASUS A8N-SLI Deluxe Motherboard
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Dvd/cd drive will not load up cd's
one day i was installing a program and the cd just wouldnt load-
i have the sameproblem since then-
i have tried some solutions, they didnot work but the might work for you-
restart computer, when the first screen after turining on quickly keep pressing F1 reapeadetly, this is the setup menu, go to the boot menu using the arrow keys go to boot priority then put cdrom first lan second and floppythird, leave harddrive for last then go to save and exit load you computer and there you go!!!!!!!!
Sep 29, 2008 | Computers & Internet
Laptop won't boot from external CD drive yet internal one is unresponsive
if you want to boot a cd e.g windows xp os disk then you have to go to the bios by pressing del or f2 or f8 ot f10 depending on the motherboard you use. try to find boot option -> boot priority or first boot device.if you find boot priority then select cdrom as first priority . if you find first boot option then also select cd rom. sometime if your disk is not bootable then it won't boot.
Jun 20, 2008 | Computers & Internet
ASUS A8N-SLI Deluxe Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
