Question about EliteGroup P4M800-M7 Motherboard
Pwr/slp/msg led not glow but the hdd led is always on
My main problem my cpu not open or bot what the main broblem of this? nay body cant help to solve this problem. no hear bot sound, the power supply is good do you thing is this bios pboblem or mother board . my cpu mother board ( elite p4m800-m7)
  • Yannick Verhoog May 11, 2010
    Is it just the light not working, while the pc boots normally, or doesnt the pc boot either?
  • 530 Answers
Hi im josh in cebu phils. may i help you? not open or no boot. If it doesn't boot or power on and no prsence of current on your pc. The main problem is motherboard. it may be no current is running on the board.because the supply chord was lost or not enough supply to make the motherboard execute.check if your power cable 16 pins is connected and the 4 pins 12 volts power support.if it loosen thats the problem. Sometimes the compatibility of your processor and the mainboard is needed.if both of these is for the first time check the compatibility of the mainboard and the processor in your support manual. good luck!
Posted on Feb 20, 2009
Where connect LED,RESET etc wires are attached
Please refer to the following list of the PANEL1 pin assignments.
Pin Signal Pin Signal
1 HD_LED_P(+) 2 FP PWR/SLP(+)
3 HD_LED_N(-) 4 FP PWR/SLP(-)
5 RESET_SW_N(-) 6 POWER_SW_P(+)
7 RESET_SW_P(+) 8 POWER_SW_N(-)
9 RSVD_DNU 10 KEY
1 SPKR 2 NC
3 GND 4 +5V
AUDIO2
USB3
SPKR1
These are all contained in the users manual. If you don't have one go to Mercury website and download it.
Mar 28, 2014 | Mercury Computers & Internet
My computer is a clone, brandname Digitek, motherboard model is Pvm7 V:1.0 Mercury, it has aproblem with power switch n the motherboard has not indicated where to plug in the sw power, hdd power, led power
The connector is right below the battery, it is marked on your motherboard Panel1, the battery is the lower right hand corner of the board, ( it looks like a quarter)
9 RSVD_DNU 10 KEY
Oct 14, 2010 | Intel Motherboard
I need assistance with the front panel cables (Power, HDD, Reset etc)
On your motherboard power is setup like so:
10 9 8 7 6 (no pin on 6)
1 2 3 4 5
1- HD_LED_P
2- HD_LED_N
3- RST_SW_N
4- RST_SW_P
5- RSVD
6- No pin
7- PWR_SW_N
8- PWR_SW_P
9- FP PWR/SLP
10- FP PWR/SLP
you have 5 connectors from the chassis' front (with cable colors):
-P LED (white)
+P LED (green)
HDD LED (yellow/white)
RESET (white/blue)
POWER (orange/white)
You just insert cables according to these nos. Do this job carefully that's why i am giving you full details about cable and its colors.
Regards
Ashly
Feb 24, 2010 | Computers & Internet
Where do i plug in the wires for my motherboard. My husband accidently disconnected them, and walked away.
The set of pins for the power switch etc are on the front left corner of the motherboard if you are looking at the board with the ports/vga/keyboard to the back. Hope this helps.
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
Jan 23, 2010 | MSI MS-6533EG-LM (MS-6533E-120)...
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
Instructions on atx case wiring to motherboard
Assuming that the computer is laying down on it's right side, and you are viewing the F panel (the front panel header) from the right side of the motherboard (the bottom of the computer), pin 1 is on the bottom left of the F panel, pin 2 is on the top left, pin 9 is on the lower right, and pin 10 is on the top right (no actual pin)...
1 HD_LED_P Hard disk LED (+) 2 FP PWR/SLP *MSG LED (+)
3 HD_LED_N Hard disk LED (-)
5 RST_SW_N Reset Switch (-)
7 RST_SW_P Reset Switch (+)
9 RSVD Reserved
4 FP PWR/SLP *MSG LED (-)
6 PWR_SW_P Power Switch (+)
8 PWR_SW_N Power Switch (-)
10 Key No pin
Usually the wires and the pins are color coded, (the colored ones being positive.) Sometimes the connections are written in very small abbreviations on the motherboard.
Jan 28, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Compaq 252608-001 motherboard
hello sosumo,
see carefully on the board there might be some sign like:
  • HDD-LED
  • PWR SWTCH
  • SPKR
  • RSET
  • PWR LED
These are the points on your board where you have to connect frontpanel connections.
For more details goto HP website and search manual for your product using your board's model no.
Thanks
Iqbal
Apr 21, 2008 | Compaq (253219-002) Motherboard
Problem with my mobo
are you sure the wires are on the right pins.
No it wont hurt the bios, but power may of fried something,
But thats rare.
here is the pins. #1 is lower left.
1 HD_LED_P
2 FP PWR/SLP *MSG LED(+)
3 HD_LED_N Hard disk LED(-)
4 FP PWR/SLP *MSG LED(-)
5 RST_SW_N Reset Switch(-)
6 PWR_SW_P Power Switch(+)
7 RST_SW_P Reset Switch(+)
8 PWR_SW_N Power Switch(-)
9 RSVD Reserved
10 Key No pin
Here is the manual
Nov 07, 2007 | EliteGroup P4M800-M7 Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
372 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
