Question about LG RZ-17LZ40 17 in. LCD Television
PSU? My LG RZ 15LA70 didn't switch on anymore! It seems to be the PSU.... Somebody knows which components are to replace? thank you very much Alberto
  • P_O_D Feb 21, 2009
    Funny enough I have exactly the same problem, went to turn the TV on tonight and nothing is working at all, any suggestion please. BTW please keep it simple as I am not a wiz when it comes to this sort of thing
    Sergeant:
  • 280 Answers
Look for any capacitors that my be puffed up or leaking. most of the time just replacing them fixes the problem.
Posted on Feb 20, 2009
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Touch control for humidity setting only goes up, cannot lower setting, is touch pad defective and can it be replaced or not worth it anymore
Yes, the touch pad may defective. But, before you try to replace it, let's try something else first.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set the humidity extraction level where you want it. Hopefully, that 15 minute time out allowed the unit to reset itself and revert back to the original factory settings.
If it didn't you can order replacement parts directly from Haier 877-337-3639 or locate a service center near you.
Hope this helped to solve the problem. Please let me know. Thanks.
Jun 03, 2011 | LG LHD45EL Dehumidifier
Need tv code for sky remote tv is an lg lcd
  • Turn your TV on.
    2. Press tv on your Skyremote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Skyremote control blinks twice.
    4. Press tv on your Skyremote control again.
    5. Key in the four digit code for your brand of TV. The light on the Skyremote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
    6. Press the standby button on your Skyremote control. If your TV switches off, press select. The light on the Skyremote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
    If at this point the LED on the Skyremote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
    At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
    8. Press tv on your Skyremote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Skyremote control blinks twice.
    10. Key in the number of the channel on your TV that you use for watching satellite TV.
    11. Press select on your Skyremote control. The red light blinks twice. The remote control setup process is complete.
LG Lucky Goldstar
20LCR1
SKY+ Rev 8
0206
ashley hawkins
26LC2R
SKY+ Rev 8
206
Peter
29FD6ALQ
Sky Rev 8
0206
Clive
32LB1DB
Sky Rev 8
0206
G Gibson
32 LC2D
SKY Rev 6
0206
Nils
32LX2R
SKY+ Rev 6 (?)
037
trevor
32LX2R
Sky Rev 8
0056,
0206
Ian
andy
32LZ2R
SKY Rev 4 or earlier
0037
GooseDog
37LB1D
Sky Rev 8
206
simon
37LC2DB
0056
g pepperrell
37LC2DB
Sky Rev 8
206
Adam Wilkinson
37LC2DB
SKY+ Rev 8
0206
Michael B
42LC2DB
Sky Rev 8
0056
Chris Lee
42PC1D/
536
mark baker
42PC1DVA
Sky Rev 8
536,0056
MALCOLM
42PX5D
SKY Rev 6
0065
ben booer
42PX5D
Sky Rev 8
1206
ANGIE
50PCID
SKY Rev 6
0065
terry
50PCIDA
0065
mr r
DI28Z12
584
Ted Warren
FLATRON
SKY+ Rev 6
0065
Justin Dean
RE44SZ21RD
SKY+ Rev 6
Sky+HD Rev 8
037
gavin court
RI 28CZ10RX
SKY Rev 6
742
Ray
RI32CZ10RX
SKY Rev 8
0742
Richard
RZ-15LA32
SKY Rev 6
065
ronnie fletcher
RZ-15LA70
SKY Rev 8
0206
MR B, BRY
RZ 20LA70
SKY Rev 8
206
stef w
RZ32L255
0063
DONOVAN
RZ32LZ55
Sky Rev 8
0206
0056
Dave R
bart simpson
RZ-37LZ55
SKY+ Rev 6
1206
Dan
Note: The LG codes that Sky have provided us to work with our newer television sets are; 0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318, 0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367. We also have some older codes; 206, 037, 060, 065, 080, 137, 191, 244, 245, 275, 318, 389, 391, 398, 405, 459, 502. The codes are stored in a database of the Sky remote. If the above codes don't work you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the new Sky remote which may have the updated codes. Best regards, LG Electronics.
If none of the above codes work try this:
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the standby button on the Sky Remote (The TV should go to standby)
5) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful.
Seems to be a handy way if you can't find the code for a TV.
It worked after about the 6th or 7th time hitting TV then Standby for me.
Jun 10, 2010 | Televison & Video
Sky remote code
0206 usually works for LG
Let me know if any success
Feb 07, 2009 | LG RZ-15LA66 15 in. LCD Television
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
LG RZ 15LA70 User Manual
I contacted the shop I purchased the television from.
I sent an e-mail to LG requesting how to obtain a copy of the manual for RZ/15LA70 LG T.V. with no resonse.
My E-mail address is katecullinan2002@yahoo.co.uk
Jan 21, 2008 | Televison & Video
LG RZ-20LA70 How do you....
I'm trying to plug in a RZ-20LA70 TV into a Sony DVP NS29 DVD player? Which wires (red, blue, green) go into the coaxial, audio L, audio R, video slots? Thanks, Simon
Jan 14, 2008 | LG RZ-20LA70 20 in. LCD Television
LG RZ-17LZ40 17 in. LCD Television Logo
189 people viewed this question
Henry  Thomas
Henry Thomas
