Question about Dell V305w All-In-One R840635AU InkJet Printer
Just installed a printer and its drivers and it loads up an extra window fairly small. it said communication not available. ive gone through all the suggestions but nothing has happened. Am i doing anything wrong
    Problem Solver:
I´ll try to give you a hand.
I think you should check some things in your operative sistem and PC configuration, here they go below:
1) The cable is in bad conditions.
2) Turn "on" the printer.
3) Type of connection; ¿USB or Printer port? ¡Check the connection and its fuctionability!
4) Drivers (controllers) that you are using. ¿Are the original and or functional ones? Go to Control panel>Sistem>Hardware tab>Administration of dispositives ("administrador de dispositivos" in spanish, sorry! -is the first tab in the dialog box.) Once there check the ports and or the controlers; if there´s an exclamation sign click over it and see what it says, you can run the automatic search of controllers made by the OS or you can choose them manually. However this, I recommend you install directly from the manufacturer, the ones compatible with your OS (Windows, Mac, Linux, whatever...)
5) Contact the vendor, by the way you should provide more data -like the OS you have, the name of the product, drivers version, type of connection.
Hope this helps.
Greetings,
SSA.
Posted on Feb 20, 2009
My Lexmark Z1420 Is not communicating with the P.C. Have checked everything and it tells me it cannot communicate with printer. The printer works with other P.C.
If its a Windows PC, you need to unplug the printer, Boot the computer in the Safe Mode, and remove the drivers (with the Device Manager). You might find duplicates. Remove them all.
Then reboot and install the drivers again, following the directions on the driver installer. Windows needs these extra steps.
Jan 26, 2015 | Lexmark Office Equipment & Supplies
Dell Photo 966 All-In-One Printer Issues. HELP PLEASE.
first purely uninstall and restart download correct driver from dell and install driver without connect printer.once installation completed your computer ask printer then connect it will be ready
Mar 30, 2014 | Office Equipment & Supplies
I need to know which port I should use to install an hp printer
Any available (Open) USB port.
(This solution applies to your other stated problem, that apparently deals with this computer also)
HOWEVER, there is a procedure that must be followed, when installing a printer for the first time, on that computer.
The software MUST be installed first, THEN the printer is attached to the computer, (Computer off), and after Windows is running, the printer is turned on.
If you attach the printer first, and THEN when Windows is running, load the software, you will get a driver conflict.
When a device, (Printer in this case), is attached to a computer for the first time, Windows will 'break it's neck' to find suitable drivers for the device.
If THE drivers are not there, Windows will match up one of it's thousands of generic drivers.
Windows: "Which drivers do I use. These or THESE?"
[ Driver: A small piece of software that allows the Operating System, to 'communicate with a device.
Windows XP and Windows 7 are two examples of an O/S ]
If this is what has transpired post back in a Comment.
It could also be that the USB port you are plugging into is bad.
Happens.
Try a different one.
What is the manufacturer name, and model number of the printer?
How are you trying to install it?
Regards,
joecoolvette
Feb 05, 2012 | Compaq Presario 5000 PC Desktop
Motherboard Driver
"Many BIOSTAR motherboards may have passed certain Windows 7 tests but that does not mean that Windows 7 drivers are available from BIOSTAR."
Do this after the windows 7 installation is completed, go to start, programs, windows update and complete all the updates, If this doesn`t helf keep updating as they are available.
Windows 7 is fairly new and some drivers are not yet available. In time, just hang in there.
Hope this helps.
Dec 23, 2009 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Exact same thing.
if it doesn't see the printer at all , and you know that driver its suitable ..and used it before...try to manually install it from the add new hardware wizard or from device manager by right clicking and choosing update driver ...It will start the installation wizard and if you previously load the driver(install it) ..let it find it automatic..but if all is OK and it shows communications errors..than is a matter of operating system and you better reinstall the windows...
Sep 02, 2009 | Lexmark Z735 InkJet Printer
Lexmark x85 all-in-one inkjet printer not working with vista
hi jjzee,
it seems that there is no available driver that you can used for windows vista.
if you want, you can try to download the driver in this link http://driverscollection.com/?H=X85&By=Lexmark and hopefully you would be able to install it.
but if still there's no luck, better call lexmark and ask if they have driver for your printer that will work with windows vista.
have a great day ahead.
Oct 02, 2008 | Lexmark X85 All-In-One InkJet Printer
Computer will not communicate with printer
Ckeck in control panel & se if the driver software installed. It should be listed in Add/remove programs. If it is, power up the piinter & load windows Vista update service. See if Vista has any patches for you're printer. If no, goto Lexmark & go to the driver section for you're P4350 printer software for Vista. While in Vista update, install any updates listed.
Click on the link provided.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista&target=
Creat a folder on you're desktop & down load the latest driver software in-to the folder you created. Uninstall any Lexmark software that might have been in add/remove programs. Install the driver software you downloaded. If all this still fails, call Lexmark since this is a new printer. The number should be in you're manul. Or you can go here for free support.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Luck!
Mike
May 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Z23 usb problem
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Apr 11, 2008 | Lexmark Color JetPrinter Z23 InkJet
Dell V305w All-In-One R840635AU InkJet Printer Logo
122 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
