Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Ocr scan for Bizhub C450
Hi i want to do OCR scaning on a Bizhub C450 Please can someone help me
  • adriaan364 Feb 20, 2009
    To rcampsr Thank you for your response! Regards Adriaan Büys Pta South Africa
    Novelist:
  • 90 Answers
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
The last post is mostly correct. You can scan via email, ftp, smb, or user box. The simple fact is you need an OCR program. Unity uses a great one. email me with questions rlane@kmbs.konicaminolta.us
Rhett
Posted on Oct 20, 2009
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
How can you scan using OCR it comes in unreadable do I need some other software installed to use the OCR function ?
On OCR software we can only scan a full text documents. Document that doesn't have any line, image, graphic. Try to scan a full text document and check if that will work.
Hope this helps. Rate if it works. Thanks
May 03, 2011 | Canon Office Equipment & Supplies
"OCR Program Missing" I've re-installed the Lexmark All-in-One & I'm still getting this werror.
hi SimpleOCR - Scanning, Optical Character Recognition (OCR) and Optical Mark Recognition (OMR) SimpleOCR is great for converting small numbers of black & white documents with simple layouts. If you need a more powerful OCR solution, please try these OCR Applications and Imaging Toolkits from ScanStore.com you appear to have some of your progam missing either re-install or go to these addresses ive found.hope this helps.
Aug 25, 2010 | Computers & Internet
HIGHLIGHTING THE TEXT
Is it possible to re-scan or re-save the document you are working on at a higher resolution?
While 144 dpi is listed as the lowest possible resolution to scan OCR text, sometimes it is finicky at that level. Also, you might want to optimize for OCR, straightening and taking out the speckles and such.
Hope that helps and isn't too elementary to your issue.
May 03, 2010 | Adobe Computers & Internet
Internal DRS error 1500:c0:3001
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage:
http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Success!
Aug 28, 2009 | HP LaserJet 3600n Printer
Ocr software missing. did not scaning
You can install the OCR software from the CD. Run the Setup and you should probably see an option to install "Additional software". Choose "Abbyy...", this is the OCR software you need.
If you don't have the CD anymore you will probably have to call Lexmark Customer Support to order one. I don't think the OCR software is available for download.
May 17, 2009 | Lexmark X5650 All-in-One InkJet Printer
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Doc chnages required
You can't.  You could try loading the Adobe professional software, but I do not think it lets you edit PDF's
If the Doc contains words you can OCR (Optical Character Recognition) it (ie read it) edit it an dthen create a new PDF.
Jan 14, 2009 | Microsoft Computers & Internet
Scan to OCR
there is a lot of OCR osftware, you can try abbyy fine reader or omnipage
Jan 22, 2008 | Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
2,714 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
