Channel 3 plays but will not record
Firs clean heads, Then cgeck for dBx jumper cable in the rear- these all have to be in for the unit to work. Then if that does not work put unit on back- remove bottom cover and the retaining bar and the reseat the third card down- make sure to line up the connectors and not to bend any pins. If this does not work then the unit needs to be sent or taken to a Teac repair person- I am in Chicago and another is in New Jersey. Other shops may charge you a lot of money but they may not fix it- that is what my customers tell me that has happened to them.
SOURCE: Replacement Power Chord and Black Grill top/back Teac A-3440
service info here:
http://www.hifiengine.com/manuals/TEAC/A-3440.shtml
Join the reeltoreel group on Yahoo groups . There's abunch of guys that might be able to help you find parts.
Please rate my help if you could.
Thanks
SOURCE: I have a TEAC 3340 reel to reel recorder and
No, that would require slowing the capstan or making its diameter smaller for the rpms it turns now. Sorry.
Testimonial: "Speedy response with the exact information I was looking for. Thanks for the help"
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
SOURCE: I need a capstan drive
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
