Question about MSI K8MM-V Motherboard
I can not find my computer display. i am alresdy check ram , cmos, smps, are correctly working
  • 530 Answers
Hi im josh in cebu phils. may i help you. Friend if not display. The main problem is in your video card or video socket. Try to check the connections first. then proceed to the video card if still doesnt work. be sure to tighten firmly the video card in your motherboard. Good luck hope i helped you.
Posted on Feb 20, 2009
My system is losing display
You can check the SMPS or replace by a new smps.remove the ram and clean the slots and refix the ram
Jan 16, 2013 | Computers & Internet
All the components are working properly but i am not getting anyh display on my monitor i replaced every thing and checked my monitor is working ram is working cpu fan is working power supply is ok smps is...
1- evolve the battery.
2- install it again but upside down.
3- turn on the PC.
4- wait 15 seconds.
5- turn the PC off.
6- install the battery correctly and enjoy. please rate.
Jan 17, 2011 | Mercury P4VM800M7 Motherboard
No display shows on monitor, no light in keyboard but both fan of smps & cpu are working, also mouse light in on.
Replace the RAM on other slot and check.
Remove CMOS cell and check.
Finally, change the powersupply and check, it could be due to powersupply not producing enough power.
Dec 17, 2010 | Intel D845GVSR Motherboard
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
Power on cpu starts but display does not come on
check volt of cmos battery with should be 1.5v
also check for RAM module get one working RAM from working system then check for reply
Nov 09, 2009 | Quadrant Celeron A , 466 MHz...
pl check step by step.
first to hang up all hardware ram,smps,processor with heatsink fan,keyboard all.
After check any beep sound comes from motherboard.
remove ram and check beep sound
remove cmos cell,ide cable and check beep
Ravindra shah
Jun 02, 2009 | Gateway (4000782) Motherboard
Upgraded computer and won't come on, no bios.
disconnect all and reconnct it.something jammed .may be *********** bord circuit is ground.
disconnect hdd ram then try.
to reattch one by one.
try with only smps ,mother bord and ram.
also check processor sitted correctly.
Nov 24, 2008 | MSI MS-6734-10 (-6734-010) Motherboard
No display smps ram Processor ok
Did U try to unmount the CMOS Battery and shorting the CLRTC Jumper? If not, first check whether UR CMOS Battery is OK. If the Battery is more than 1 years old, try replace it.
Mar 11, 2008 | Intel D845GVSR Motherboard
MSI K8MM-V Motherboard Logo
20 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
