Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart Grind & Brew DGB-600 fills up water in goldtone filter;
My machine fills up the goldtone filter with water and small amount of ground coffee....thus the carafe pot makes only a 1/2 cup, because all the water is stuck in the filter....
  • 8,596 Answers
Some fine-grain coffees are too fine for the Gold Tone Filter. If this is the case, remove the Gold tone Filter and use paper filters only. You may have to wash excess grinds out of the black filter basket, since there may be a few stuck in there now - don't take the filter basket apart - just rinse it out with water.
Also, don't use a paper filter and the gold tone filter at the same time.
-Tha Mp3 Doctor (also loves Cuisinart)
Posted on Feb 21, 2009
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
My cuisinart grind and brew model dgb-700bc shuts off right before it is done brewing and i am getting coffee grounds in my coffee pot
Too much grounds or not running through fast enough. Right filters? basket flow hole vlesr? Sounds like it's backing up and flooding causing the grounds to get by yje filter. If you dare, **** the hole out just a tad. with the end of a sharp knife. not too much. You can always take out mor. This is called consuner calibration. Good Luck -Ned-
Sep 19, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Coffee Machine Brewing Water
Try an experiment - brew a test cup, but use only a small amount of grounds in the brew basket (use a paper filter) [or else, put the grounds in the gold tone filter basket]. See if the machine makes coffee (albeit weak coffee). If it does not make coffee, see if the water is draining properly from the brew basket, or if it is leaking over the sides of the brew basket. Also, make sure the lid to the brew basket is completely open and in the correct position.
If you still get water only in the caraffe, replace the brew basket. The part costs about $11.95 with shipping - or even call Cuisinart to see if your 3-year warranty will cover the issue.
-Tha Mp3 Doctor
Mar 03, 2009 | Cuisinart Thermal DGB-600 Grinder
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Grind and Brew thermal (model CUI DGB 600BC)coffee filter cup hard to open, now won't close. Cup where beans are added, bean cup difficult to open as well. Need to find repair place near zip code 95127.
That problem is endemic to this grind and brew only - find out if you are still in warranty - try and get a DGB-550BK as a replacement - the 600 is the only one with this problem. Replacing it with the same model will likely lead to the same result.
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Dec 02, 2008 | Cuisinart DCC-1200 Coffee Maker
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
DGB-600 Will no longer grind coffee
I am having the same problem, can someone please help?
Oct 09, 2007 | Cuisinart DGB-600 Coffee Maker
Automatic Grind not working
My grinder was not working properly, because the blade was not rotating freely. So we carefully chipped away some caked on coffee residue. Then it worked for awhile, but started to sound weird and only partially grind the coffee. So we applied a small amount of vegetable oil to the blade and let it seep down a little, and that was very succcessful! Just needed a lube job!
chrisnap49
Oct 23, 2006 | Cuisinart DGB-300 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
152 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
