Question about Compaq Presario 1692 Notebook
I have Toshiba Tecra laptop when i power it on it produces continuous beeping sound with No display. What can be the problem?
    President:
  • 2,351 Answers
continuous beeping is most commonly generated because the memory is improperly seated or missing memory. Try removing/clean the memory contacts & reseat. Clean contacts with a cotton swab & one or two drops of house hold alcohol.
Look to uTube for help getting at your memory;
http://www.youtube.com/results?search_type=&search_query=how+to+upgrade+memory+in+a+Toshiba+Tecra+laptop&aq=f
Thank you for using FixYa!
Mike
Posted on Feb 20, 2009
Toshiba tecra A9 when I press the power button I get the power indicator light and the hard drive light. The hard drive starts to spin for about 1 second and everything shuts off and all the lights are...
there is a short circuit in your laptop. the power circuit cut off the power fpr protect the circuit. need to dissemble and remove parts cd hdd and ram other parts you can remove. power up and check the continuous run , no need video, after replace the ram test the display. also your lcd is bad or converter may be shut off, there test without lcd.
Oct 06, 2017 | Toshiba TECRA A9 PC Notebook
Toshiba Tecra S1. My laptop has power but will
It has a memory problem, take the laptop to your local store and ask if they will test the memory for you, if it is the problem then you will have to purchase a new memoy module.
Jan 29, 2010 | Toshiba Tecra S1 Laptop Notebook
I had a Thoshiba Tecra A3 Laptop nwhich is not loading OS
When you hear about the long beep it is a RAM problem which is not totally inserted. You need to check the RAM remove and reinsert it again and try to power on.
Dec 13, 2009 | Toshiba Tecra A3 Notebook
When power on a message display on screen "UPDATE BIOS"
You have to update your bios. Go to toshiba website, search bios drivers for your laptop model, download them and flash the bios.
Aug 27, 2009 | Toshiba Tecra 500CDT Notebook
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
May 26, 2009 | Toshiba Tecra 8000 Notebook
Toshiba Tecra 8100 PIII laptop not booting
It could be a hard ware isuse. Try this.
If you have extra memory or removable Ram ( usually located on the bottom under a panel) Try removing it and starting it, with the ram removed. Then try putting it back in and starting it. If it works, it may be bad memory or it just needed to be reseated. Do this also with the cd drive and wireless card if it is removeable.
also try this with the battery, plug it in and remove the battery and see if it starts.
alot of laptops, like computers will not boot if there is a hardware issue.
The Beeping is a code. The number of beeps and how it beeps usually indicates an issue.
you could look the beep codes up on the toshiba website is the support center.
Good luck.
Apr 15, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Toshiba Tecra 8100 will not boot, even the toshiba boot screen not displayed
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/faq.jsp?z=234&service=EU&from=faq_selection&CFID=BIOS&FID=TRO0000000b07
Thats a link to info about bios updates on the tosh website. If you're not getting to the toshiba screen then POST has not completed which means that either there's a hardware problem or the bios is corupt. If you're sure the RAM is ok try flashing the Bios.
Problem is though, to make the bios update disc, you need a working computer.
and, err, It'll probably have to be a toshiba!
(sorry, not my fault!)
Mar 19, 2008 | Toshiba Tecra 8100 Notebook
Compaq Presario 1692 Notebook Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
