Nokia 1100 Logo
Posted on Feb 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When SIM is changed,security code is not supporrted
When sim changed with another, not working that is security problem
Anonymous
Level 2:
  • Expert 79 Answers
  • Posted on Feb 22, 2009
Anonymous
Expert
Level 2:
Answers
79
Questions
Helped
24301
Points
233
Seems like your phone is locked to the previous sim by the previous user, if that was not you. or your phone is locked to the network. you need the key to unlock the network or phone-to-sim.
How to resart in starting if put new sim in my mobile it asking security code how im restart my mobile
If it is a used phone and it was never wiped. Then the old security code is active. Changing the sim does not change the security code of the device. If it is asking for a sim security code, then the sim card is locked and you must have the code or the sim is just a piece of plastic. Did the service provider put a code on the sim and forgot to tell you.?..Take the sim back and ask for another without the security code on it. Sims can be coded so that if they are stolen they cannot be used in another device.
Jan 24, 2015 • Cell Phones
Forgot my security code for nokia 105 type RM908
You will have to break the security code with a particular software.
Jan 30, 2014 • Cell Phones
1helpful
2answers
I forgate security code and my phone is not support aother sim
ur default security code is 12345. u can try it. but if u have changed ur security code so u need to reinstall ur phone programe. then u security code come default settings.
When SIM is changed,security code is not supporrted .nokia 1200
turn off code request with ur default sim & try
Feb 20, 2009 • Nokia 1100
1helpful
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
3helpful
How can i change security code which i forgot nokia 3110 classic?
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Security code
SIM pin code:
Master Reset Code
6helpful
4answers
Security code for 6133
Open phone, don't go to any menus. Dial *#7780# and press green send button. It will say if you would like to restore factory settings and say yes. Then it asks for a code. This is when you put 12345 and then press OK. This should help because it did for me.
GOOD LUCK!!
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
