Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Water not hot dishes cold - Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
  • 117 Answers
Looks like you have a problem in the heating circuit of your dishwasher. It could be a faulty control board, safety thermostat, heating element or wiring. Make sure you run the water at the sink prior to every cycle to purge the cold water out of the pipes. I have a lot more info under my tab dishwashers.
Posted on Feb 25, 2009
Water not heating
Dish washers only use water supplied from the hot water side of the pipes under the cabinet or sink, so if you installed the dishwasher yourself, be sure that you ran your inlet water line and connected it to the hot water side, and not the cold water side. The dish washer has heating elements inside the machine to dry the dishes, not heat the water. If this is hooked up correctly and you are still getting cold water to heat the dishes, the problem may be that the unit is too far from the hot water tank. In that case, you may need an auxiliary hot water tank installed near the dishwasher under the cabinet. They make small tanks for such purposes.
Dec 14, 2014 | Dishwashers
Dishwasher not drying dished with any heat source. Dishes washed in cold water.
Most dishwashers are plumbed to the hot side of the hot water side of the faucet. This should provide hot water for washing the dishes. Perhaps this dishwasher was plumbed to the cold water side by mistake.
Most dishwashers have a heating coil most of the way around under the bottom sliding/rolling dish rack. The heating coil may not be working, which would be consistent with the dishes not drying at the end of the cycle. Possible causes include incorrect setting selected on control console (push buttons) or timer, heating coil disconnected from electrical source at one end or both ends, faulty control circuit inside the timer, faulty wiring between the timer/control circuit and the heating coil, burned or pitted contacts in the control circuit.
May 23, 2011 | Dishwashers
There is a hot water valve & a cold water valve on the Dexter T300 machines but it is a 2 coil valve. does the hot water valve supply only hot water or does one side provide water to perhaps the...
supplies hot water when needed, cold water when needed. and then warm water when needed. so the second coil is for warm water. it basically mixes the hot and cold water.
Mar 17, 2011 | Washing Machines
Do I connect this dishwasher to the hot or cold water supply?
Always to the HOT WATER supply... If you want a proper dish-washing; you can connect it to the COLD WATER supply but in the end your dishes will look just a little bit less dirty than when you have inserted them into the slots...
Mar 02, 2011 | Microwave Ovens
Dishwasher is not throughly cleasning dishes
it has alot to do with the kind of saop you are useing,,,and lots of time the water is not hot enough to do the job right,,so i would run my hot water in the kitchen sink to make sure the water is hot first. if it is hot in the sink then it will be hot in the dish washer,,,but if it is cold then the dish washers water is cold to,,best to warm water then see what happens from there,,,remember the type of soap you are using to
Feb 18, 2011 | Maytag Dishwashers
Washes but water does not heat up and dishes cold
The dishwasher does not heat up the water. The water should be hot coming into the dishwasher, check your hot water supply source, whether it be the hot water tank or be sure the water inlet for the dishwasher is not connected to the cold water line
Jan 09, 2011 | Zanussi Dishwashers
Hot or cold water
d/w need to be connected to the hot water or your dishes wont come clean
Nov 28, 2009 | Dishwashers
Water supply for dish washer
normall water is cold water for dishwasher
Jun 03, 2009 | LG Dishwashers
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
