Question about HTC P3300 Smartphone
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
  • 1 more comment
  • reva_sivaraj Feb 20, 2009
    thank u for ur input. Will try the mentioned options
  • agnesh_kumar Feb 20, 2009
    not a second of backup is being given by it
  • baskasi_26 Apr 03, 2009
    today i experienced the same.. i cannot charge it. red light is flashing. it is starting , battery showing 0 . and some time later , it is shutting down. i ordered new battery but after replacing battery , i dont know what to do if it doesnt solve my problem.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Posted on Jun 05, 2009
The phone shows 0% charging even if the battery is charged using an external charger. if the phone's charger is used, the battery doesn't charge for more than 4% and comes back to 0% again. the phone runs well for the time the charger is put on. if removed, the phone shuts down immediately.
Posted on Jun 03, 2010
Have the same problem on mine. A small plastic part in the usb-connector on the phone is broken loose on mine. Have tried to open the phone, but have not succeded...
Posted on Jun 09, 2009
    President:
  • 1,223 Answers
Its a battery issue u have to try changing the batt if t helps it might be the charger as well try charging from another source like usb charger from pc thru usb cable came with pda see it helps
Posted on Feb 20, 2009
My HTC P3300 has died, does not want to turn on, and when it does, it freezes and stays the same until i remove the battery. It still charges the battery, but does not want to turn on. Please help
ok it could be one of two things so tru this first..
buy NEW battery..
charge while OFF!
LED goes off when fully charged.
if after this is does not work then add me to messenger and ill walk you through the steps to flash the rom on the device.
raving_nanza@hotmail.com
Feb 18, 2010 | HTC P3300 Smartphone
I have htc p3300. once started charging its get switched off automaticaly
does the charge light stay on (orange led) on or does it go green or flash on-off orange?
could be battery issue..
on the charge slot on the bottom of p3300 there will be 2 bins left and right inside. try bending them slightly - ONLY slightly tho incase it snaps.
use a needle.
its wat im doing at the moment, im currenlty trying to figure this out so ill keep you informed if i find the soloution.
atm i have to have my phone on charge to use it, otherwise it just goes off but thats how im getting it to charge atm.
if im not in touch..
Oct 28, 2009 | HTC P3300 Smartphone
HTC P3300. WM 6. Speaker won't turn off during calls
Hi
I have a similar problem. Some time my phone works fine and some time the speaker is on and can't switch it off.. this is due to the charging pin, loose connection.. you need to handle carefully while detaching your phone from data cable or the charging wire.
Oct 07, 2009 | HTC P3300 Smartphone
HTC p3300 often hangs up(black screen, no response to any buttons
buy a NEW battery..
charge while OFF!
LED goes off when fully charged......
DONE!
thats all it is mate :)
Aug 16, 2009 | HTC P3300 Smartphone
Battery problem: P3400i
Sounds like its probaly the battery, they dont last forever, try here for a replacement - HTC P3300 battery
Jun 06, 2009 | HTC P3300 Smartphone
HTC P3300 shuts down.
There is a big chance that if you exchang you batterry it will be just fine.
Good luck
Apr 27, 2009 | HTC P3300 Smartphone
Htc p3300
new battery!
charge while OFF!
when charge LED goes off its done!
Nov 05, 2008 | HTC P3300 Smartphone
P3300
new battery
charge while off
led goes off when done
May 22, 2008 | HTC P3300 Smartphone
The phone is not switching on
new battery
charge while off
May 11, 2008 | HTC P3300 Smartphone
HTC P3300 Smartphone Logo
1,002 people viewed this question
Top HTC Computers & Internet Experts
Justin
Justin
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
