Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Sony handycam dead
My sony handycam was rained on and after two days it could not operate on sich on.
The baterry and the power cable are ok as i have tested with oanother good camera
please help
  • 423 Answers
I am sorry but, rained on...it's probably dead.
Posted on Feb 20, 2009
  • Rob
    Rob Feb 25, 2009
    How can this solution be inappropriate? You left the camera out to be rained on? Do you want a magic word to make it all better? I feel bad for you because there is nothing anyone can do about it, except you. Buy a new camera.
Sony Handycam 70x taking too long to import viideo to windows 7 OS
if it is taking 2 hours to import ( download ) then there is something wrong
23 mb should take 10 minutes at most
read the user manual for the cam operation , trouble shoot section slow download
May 07, 2017 | Sony Handycam Video Cameras
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
Will not turn on or start up..Sony Handycam DCR-DVD300 DVD
Try resetting the Camcorder to the factory settings by pressing the reset button. If the issue persists, try power resetting the camcorder. To power reset, remove the battery of the Camcorder and press and hold the power button for 30 second(or turn the Power switch to ON position for 30 seconds) and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 27, 2010 | Sony Handycam DCR-DVD300 DVD Camcorder
My Sony Handycam DCR-PC9E mini DV Digital Camcorder is totally dead. Even powered the camcorder at Camera position and reset it according the operating manual. Yet there is no response at all . Is there...
This is a simple case of the Bat going dead, it does look from what I read that the Sony batteries do not seem to stand up long these days, I am hearing of this daily on the Mini Cameras, where my old faithful 8mm camera bat is 8 years old and as good as new.
Jun 13, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
Sony handycam was not connecting
Ha, you are so right, if you are on Windows Vista/or the new 7 then your Sony camera will no longer see a connection so you are going to buy a Firewire yes? as that is the only cable that works these days with Sony, unless you return to windows 95 or XP that is.
Jun 07, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Sony Handycam Dig 8 doesn't recognize tape when trying to record
If it has memory stick, Make sure your memory stick is in. Your memory stick is full. Delete the unwanted pictures from the memory stick or use a differnt biger memory stick.
I looked in the manual. It seems your camcorder does not have a slot for memory stick. But you may still save pictures on the tape. Here is the link to download the manual
http://www.docs.sony.com/release/DCRTRV140.pdf
Please read Page 40 "recording picture on the tape".
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony handycam dcr pc350 video capture problem with vista
As per Sony Support, DCR-PC350 is compatible on Vista, however there is an update of picture package available at Sony Support.
Download update and check the camera file transfer operation.
Jan 16, 2009 | Sony Handycam DCR-PC350 Mini DV Digital...
Import videos from handycam to computer
i am unable to import videos from my mini dv digital handycam to my laptop with vista as operating system.is a i-link cable required or usb cable will do? i have the picture motion software and import from handycam software dowloaded through net. can u help me out???
Jul 20, 2008 | Sony Handycam DCR-HC36 Mini DV Digital...
Sony handycam DCR-PC330E Mini, purchased in Tokyo, April 2004 - Was working as normal, then suddenly went 'dead' - no light showing when on charger (which had been working fine up to date), tried another...
This is not a monster you wanna open and play with as I've seen this puppy and its loaded with flex cables connecting all the differant pcb's together. You wanna take this or send out to a camcorder specialist please. You also need a special set of these cables to work on this unit as well as a few special service jigs. Good Luck
Apr 11, 2006 | Sony Handycam DCR-PC330E Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
157 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
