Apple iPod Nano 4GB MP3 Player
Problem for Apple iPod Nano 4GB MP3 Player
I went to plug up my ipod nano third generation
By tabitha_smit on Feb 20, 2009
I went to plug up my ipod nano third generation the 8 GB and it is frozen on the last song i listen to and then I unpluged it and went to push play and it wouldn't un-freeze.
Solution #1
posted on Sep 13, 2009
Not Rated)
meeknotweak
Rank: Guru  Apple Expert
Rating: 90%, 181 votes
Try reseting it, It worked for me. Hold down the "Menu" button and the middle button for about 7-8 seconds.
Hope this helps!
Was this helpful?
Yes
No
Solution #2
posted on Jun 28, 2009
Not Rated)
mneilsen2084
Rating: 91%, 170 votes
Last Modified: January 28, 2009
Article: HT1320
Old Article: 61705
Summary
Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Please let me know if this does not resolve your issue
Was this helpful?
Yes
No
Solution #3
posted on Apr 23, 2009
Not Rated)
jazzyboy11
Rating: 87%, 391 votes
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Was this helpful?
Yes
No
Popular Solutions for Apple iPod Nano 4GB MP3 Player
Questions and Unsolved Problems for Apple iPod Nano 4GB MP3 Player
Do you recommend Apple iPod Nano 4GB MP3 Player?
Answer
Answer
i cant add songs to my ipod evertime i try it says ipod cannot be synced and error 13001. How do i... (More)
Answer
will not turn on or show up on the laptop. will not turn on
Answer
button on my ipod nano 4th generation is not skipping forward have tried a full system reset is... (More)
Answer
how can i change my new ipod back to english can i just reset it and choose english again easily
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in , NY
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
