Question about Funai PY90DG DVD Recorder
The dvd recorder and it hdd can't record since hdd full
I have two hdd recorders with vcr and hdd 160 gb each one.
The problem rises when the hdd was full and i deleted datas on hdd I did always the same with another dvd recorder lg and never have any problem like funai.
the vcr is still working the dvd olays dvd disks but cannot records as well as hdd. it writes error system.
Would you please be so kind to let me know how can I resolve this problem..
Thank you so much in advance and hope read you soon.
Miss Fouzia Morocco
  • unior2006 Feb 20, 2009
    Thank you so much for your quick reply but it doesn't solve my problem.
    I ve tried several time however i read always the same message on dvd recorder: ( cannot format system error ). I format hdd trought computer it doesn't work too.
    Also I ve tried another new hdd but nothing special always the same message.
    Thanks a lot and I ll be awaiting your sugestion.
    Miss Fouzia Morocco
  • Anonymous Feb 22, 2009
    try cleaning the laser lens , and if you deleted info on the hard drive(hdd) that is for the system , then you will have to get a software disc and or software update disc from funai for the hdd , do not try to use a computer to format the hdd , files from funai are put on there to control or update the system.
    President:
  • 1,223 Answers
Miss Fouzia Morocco
pls try to format all HDD first backup ur data by connecting the dvd recorder to pc then format ur hdd it will help lemme know
Posted on Feb 20, 2009
  • Shoaib Rais
    Shoaib Rais Mar 21, 2009
    pls update ur rating i tried to help u these ratings affect our rankings thanx
    i am in search of solution to ur problem will write back
While playing vhs tape, the sound is great, but the picture comes and goes.
That's usually dirty or worn out heads or not enough take up tension in the tape
Sep 27, 2014 | Toshiba RD-XV49DT DVD/DivX/VHS...
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
Can you record a dvd from vhs on this system ?
No you cannot - This is a DVD *PLAYER* / VCR combo - which means it features a DVD player & VHS recorder in one - you cannot record onto DVD - You can however watch a DVD while recording your tv program on the VCR.
I hope this answers your question.
If you want to convert your VHS to DVD you will need to purchase a standalone DVD recorder - I personally do not reocmmend the DVD recorder / VCR combos - or you can use a HDD/DVD recorder which stores recordings on a hard drive and later you can burn them on DVD, they allow editing, more flexible recording options, etc
Aug 17, 2009 | Toshiba SD-V291 DVD Player/VCR
Can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
Apr 27, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Time shift to hdd
The only way I was able to do it is to capture "while playing back" to another recorder "VCR" DVD"
Dec 10, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
DVD Recorder/VCR 80 GB HDD
Tyr using -r dvds ,,,,,that might resolve your problems
Mar 25, 2008 | Televison & Video
Recording from VCR to HDD
The VCR tape contains a copy inhibitor along it's length, so cannot be copied. the only way to make a copy is to use a truly analog route, without any copyright checking getting in the way. I think this is mentioned in the manual.
Feb 21, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Funai PY90DG DVD Recorder Logo
361 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
