Question about Xerox WorkCentre M-24 Color Copier
LOcation of workstaion 24
The 2 guys that work in the office have put the workstation24 in a corner with my chair directly backing onto the machine
  • 2,072 Answers
I can tell you that does not meet space requirements for ventilation, service room or safety.
As far as your health, with the filtration and safety requierments involved with those machines, you are fine.
But any smart service rep will refuse to work on it, and they do not have to in that type of location.
that type of location will cause operational problems. I can guarantee a location like that does not meet ventilation requirements.
Posted on Feb 20, 2009
What is the Charles Pollock Executive Chair?
The CharlesPollock Executive chair, designed by Charles Pollock back in 1965, was one ofthe most popular office chairs at the time. Today, it is one of Knoll's mostpopular office chairs.
Jul 30, 2012 | Furniture
Where can I buy leather office chairs online?
Nowadays you can get everything from online and wherever you want to order and deliver your order so you don't need too much effort to find a Best Chairs dealer online. If I talk About the Office Chairs in Delhi location buy online you can go fo the Sunview Seating Solution located in Delhi. They are leading manufacturer of Office chairs and chairs availability in different designs and prices.
What is an office chair?
An office chair isthe type of chair that employees use during their office work.
What do you call the piece of plastic that you put under a rolling office chair?
The piece of plastic or any other material used to put arolling office chair on top is generally called a surface mat.
May 29, 2012 | Furniture
Ordered Fuego Multi-Function Task office chair via Office Max online on 6/14/2011. Received UPS delivery of chair on 6/15/2011. However, there are no assembly instructions included. How can I put it...
step 1: press the 5 casters into the holes on the star base (it's a firm press until they snap into place) turn it over so the wheels are on the ground and push the gas cylinder into center hole. place black sleeves over it. set it aside.
step 2: attach armrests to seat base using bolts (I) and washers (K) (the longer and thinner bolts and smaller washers) using the allen wrench supplied.
step 3: attach the seat plate (the thing with the 3 handles) onto the bottom of the seat cushion using bolts (J) and washers (L) ( the fatter and shorter bolts and larger washers) usint the same allen wrench.
step 4: place the set onto the base into the big hole that acceps it. then sit on it to ensure it stays, otherwise when you pick up the chair it will come off the base.
step 5: slide the seat back bar into the groove where the know shows at the back of the seat. you may have to loosen that knob first. when it is in, press the little black plastic button (M) into the hole at the bottom of that seat bar to keep it from sliding out when you pull it up to adjust.
step 6: play with the levers to learn how to do different adjustments.
step 7: congratulate yourself and be proud that you did it!
Oh, make sure all the bolts are tight before putting into use.
Jun 15, 2011 | Office Equipment & Supplies
Want to get back of chair off the chair
If its a regular office chair then the solution is fairly easy...
Look underneath the chair and there should be a bolt or two screws holding the 90degree arm that the back is attached too. Remove those and you'll have it in two pieces.
Sometimes office chairs have the 90 degree arm attached to the base. In this case you would need to look under the base for the main bolt. Remove that and then the spring inner pole should slide out. From there simply disassemble the reminder bolts.
I always keep track of where the bolts and/or screws go, because when you go to put it all back together it'll make the job much easier. Draw a diagram if needed.
Side note, if you could provide what brand of chair this is I may be able to assist you further, the above is just general knowledge.
Feb 21, 2011 | Office Equipment & Supplies
Xerox WorkCentre M-24 Color Copier Logo
853 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
