Question about CTX Ez Book 700 Notebook
Where is the battery on the motherboard? CTX EZBook 700
Some one told me to disconnect the battery on the mother board for afew minutes to deactivate the password to get to the setup (F2) a fix my computer. CTX EZBook 700 series Now I have it all apart down to the motherboard and can't idenify the battery. What am I looking for, shape, size, etc.
Thanx in advance!
PS Hurry it's all over the place, so many screws!:)
    Problem Solver:
  • 12 Answers
Hi..!
battery is like a silver coin....
round in shape....
Amit..
Posted on Feb 20, 2009
  • 3 Answers
Regal, the battery is locate on FLOPPY/HDD-side at the rear (LCD) side of motherboard ...as matter of fact battery can be visibly seen however not remove/fiddled with from inside the HDD tray opening. I place a thin plastic shim between battery & battery retainer in order to break battery's contact ...motherboard side was impossible
as it turns out it worked ...I'm up and running
Posted on Nov 03, 2009
Ezbook
??? freezes
If at boot??? ...it could be memory or lack thereof ...could be OS improperly installed. In fact it could be a plethora of software hardware problems
. Please be more specific with your questions and you get better answers. at best this is the best answer I can provide for you :)
Jul 07, 2013 | CTX Ez Book 700 Notebook
When i turn on the power green light on left comes on -no other lights display screen will not come on
hello,
you might be having a no POST problem -remove all other device that are connected to this computer -remove battery and power cable -after a minute try to power on w/o battery just the power curd - see it it will work -if still not working turn off notebook try to use an external monitor or LCD plug that to the vga port at the side power on see what will happen -if you are still having the same problem you might need to bring computer to a local tech and have the Motherboard looked at, it might need repair or replacement.
cheers
Feb 25, 2011 | CTX EzBook V92C266 Notebook
EZ book pc7 netbook EZ-72A will not turn on . no lights ans screen remains black
With external power removed, disconnect and reconnect the battery.
Jan 19, 2011 | CTX EzBook V92C266 Notebook
My unit won't power up - power supply is good and not sure about the on switch any help would be appreciated -- motherboard is in an old HP Pavlion 700 case
Remove the little watch type battery from the mother board check the voltage with a meter should be about 3.5 volts. Then replace the battery on the mother board. This battery holds memory within the Bio chips on the mother board, if there was a problem that it sensed for turn on it will be in the Bio's memory, and maybe not allowing the computer to turn on, by removing the battery for a few minutes, the Bio's forget they had a problem, if you will. and the computer might turn on.
If you have all the voltages to the mother board from the power supply, it should turn on.
unless there is some reset circuit interfearing with it turning on. Or you might have a blown fuse on the mother board, I would check everything I could, and try everything I could, and if you still cannot get it to turn on take it to a computer shop and spend a few bucks for them to fix it.
Nov 11, 2010 | Mach Speed Matrix P4MSD-800 (P4MSD-800 D2)...
CTX EZbook 700 is missing...
there is a battery on the motherboard this must be removed for at least 1 minute this will clear he bios password.replace the battery and password will be gone.
Feb 18, 2009 | CTX Ez Book 700 Notebook
Need help upgrading my labtop
You need the windows 98 se installation cd and product key.
Microsoft no longer supports or makes these so your going to have to find one used, from ebay for example:
http://cgi.ebay.com/MICROSOFT-WINDOWS-98-SE-SECOND-EDITION-CD-NEW-with-KEY_W0QQitemZ320231977797QQihZ011QQcategoryZ162QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Mar 27, 2008 | CTX Ez Book 700 Notebook
Blank Screen
MS-DOS edit command help edit myfile.txt <press enter>. This would bring up a blank edit screen, as long as the file is saved upon exit this will create the file myfile.txt.
Dec 16, 2007 | CTX Ez Book 700 Notebook
Computers & Internet Logo
358 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
