Question about HP Compaq nx7010 Notebook
Projector giving green picture it is ok with RCA inputs ok with S video input but if i connect component connector like 15 pin vga from dvd player it gives green picture but with same cable if i connect pc piucture is ok , i have checked 2 dvd players as well have same problem
  • 13 more comments
  • Shoaib Rais
    Shoaib Rais Feb 20, 2009
    i have checked the settings it doesnt help it is set to auto detect i have also tried it manually but no outcome
  • Shoaib Rais
    different cables tried result is same pins are ok they are not bent as well
  • Shoaib Rais
    it is Epson S3 powerlite but manual doesnt help
  • Shoaib Rais
    on the right side as always the other side is for monitor out i cant use it
  • Shoaib Rais
    no i dont use the splitter i use separate cables to connect both manually, and i have tried selecting input to component manually but it doesnt help picture remains green , no matter what ever i do change cables or dvd players or settings proj seems ok cables seems ok dvd player 2 cant be faulty i dont knwo what is the soultion
  • Shoaib Rais
    i have asked them they are unable to help and said same things as u said but it did not help i think i have to be on s-video input for rest of the time thanx for tryin hard thanx
  • Shoaib Rais
    so nice of u , thumbs up for ur enthusiasm !!!!!!!!!!!
  • Nicolas
    Nicolas May 11, 2010
    Nothing to thank me for, i wish i could solve your problem, but i couldent. Its sad that you need to use that poor S-video connector, the differens betwin a S-video and the VGA is like night and day.
    Well, i dont give up, i will search for answers for you, and if i find any i will reply them here for you.
    Nic
  • Nicolas
    Hi !
    Talked to my friend at Epson again, he sugest that you contact Epson for further help, contact them and the will help you.
    You will find all info here:
    http://www.epson.com/cgi-bin/Store/suppo...
    Nic
  • Nicolas
    Hi again!
    I just spoket to a friend of mine who works at Epson here in sweden, he told me that (as i sayed before) its a setting known problem. You will gett a green picture from a dvd-player if you dont manually change the incoming signal to component.
    Do you use a splitter to connect both your pc and dvd to the projector or do you move the cable betwin them?
    Nic
  • Nicolas
    On the projector, you have 2 vga ports, witch one did you connect the cable on? the one to the right or the one to the left ?
  • Nicolas
    Thanx, i know that the manual dosent help sometimes, but some forums may help:) I will ask around and see if i can come up whi a solution for you,
    Nic
  • Nicolas
    Whats the name and model of your projector? i will try to find the manual for it so i can analyze your problem better.
    Nic
  • Nicolas
    Hmm...
    Strange, its almost always the sittings with problems like this.
    Check the connectors on the cable and make sure that they are full pin connectors
    Nic
  • Nicolas
    Its just a setting issue, you need to set the projector, it dosent automatic recognize where the sourse is and where the signal comes from. Even if the signal passes thrue the same cable there is differens from a dvd and a pc. Every time you change the signal source you need to change the settind on the projector. You have to find the right settings, thats all you need to do for making it work.
    Nic
    Problem Solver:
  • 5 Answers
I think, the issue might be because of lenght of the composite cable. Not all projectors can "recognize the signal" on too long composite cables, try a "standard size" cable used on monitors, it is i THINK 1,8 feet long...? Dunno. Try two short cables and see if you get "green" - if not, then your cable is too long and gives the signal to much "resistance", so your projector can "read" only one of the color channels, in your case green. If your projector setup requires long cables (and it usually does ;) ), you will have to stick to Cinch connectors and analog video signal, which I have tested on 35m long cable without any visible quality loss. Hope this helps. ;)
Posted on Mar 10, 2009
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
When playing a DVD, I get sound but not a picture. The message on the screen is no input, check input. I have checked the cables at the DVD and at the TV and both are connected correctly, i.e. red to...
Have you tried using standard RCA AV cables? yellow-red-white - to TV. Or have you tried using an S-Video cable (a 5-pin mini DIN plug) between your DVD player and TV? if your TV has S-Video input, and your player has S-Video output, a cable for this should be easy to obtain and connect. Not expensive either.
Your TV should automatically detect the connection of S-Video (if it has this feature). S-Video is better quality than standard RCA yellow AV cable. (you can leave the existing component video connected)
You can also check your DVD player 'setup' maybe it is incorrect - make sure when using component video (red-green-blue) to set the player's output to progressive (for a TV that supports it) - unless it is already set to this.
If everything in the setup menu checks out OK, go with the cheap and easy S-Video cable suggestion. Radio Shack may sell these.
Apr 04, 2011 | Sony DVP-NS575P DVD Player
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Why does the tv have component video when its an analog tv and how do you hook it up
Component video IS analog. It is also known as Y-Pr-Br. These connections are typically RCA connectors colored Red/Green/Blue.
Component will give you the highest quality signal for analog connections (vs Composite Video (yellowRCA) or S-Video(the round 4 pin connector) Of course HDMI will be best if it is supported.
Keep in mind video signal formats are NOT interchangable, you cannot plug a Composite Video into a Component Input
All you need is a component source (typically a DVD player) and 3 RCA cables and match the colors up.
You will also need to connect the Audio connectors (Red/White) with RCA cables, as the Component is Video only
I hope this helps,
Magoo
Mar 11, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
Hd outputs or connectins
The only HD input on that monitor that is true HD is the 15 pin VGA input connector. It can be set in the TV menu to be used as an RGB input OR a color difference component input (Y, RY, BY). You will need a 15 pin connector that breaks out into 3 sperate cables; the ones I've seen break out into 3 BNC connectors and then you have to use dapators to convert them to standard RCA pulgs for connection to most consumer devices.
Oct 27, 2008 | Sony PFM-42X1 Plasma TV
I dont know how to hook up a dvd player
Depending on the model of DVD player and the TV you are trying to connect it to you have various inputs and outputs.
If your have an HD (High Definition) DVD Player and a HD TV the best input to use is HDMI. Both device would have an HDMI interface whereby you could connect them together.
If you have a standard DVD Player you have usually 3 other input/output options, RCA, S-Video, and Component. Your RCA jacks are colored Red, Yellow, and White. Your S-Video is a larger circular jack with several pins. The Component cable has Red, Green, and Blue.
Of the three above the Component Cable connection is going to give you best picture quality. S-Video is second and RCA is third. You just need to match up the connectors on your TV and DVD and get the cable that accommodates the best picture quality. Again for clarification below are the interface options for best quality to poorest:
1. HDMI
2. Component
3. S-Video
4. RCA
Hope this helps.
MO
Jul 14, 2008 | Televison & Video
How do i connect my projecter with my pc
Your Sharp XR-10X will only allow video inputs through the:
1. RGB/ component input (15-pin HD)
2. composite video input (RCA phono color yellow)
2. S-Video input ( 4 pin mini-DIN )
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output (4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Good luck and kind regards.
Dec 03, 2007 | Sharp XR-10X Multimedia Projector
BenQ PB6100 Component input problem
You can get high defintion by connecting a cable that is component video source on one end your (dvd) and VGA (to projector)on the other. This cable is available from cables to go.
Aug 24, 2007 | BenQ PB6100 Multimedia Projector
HP Compaq nx7010 Notebook Logo
229 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
