Question about HP LaserJet P2015dn Printer
Problem in all print paper are lines & ... how to solve this problem
    Sniper:
  • 121 Answers
Image defects on LJ printers are usually the toner cart. or the fuser:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the image Defect on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Posted on Mar 28, 2009
Paper out & printing page, tallygenicom t6212, help!!!
Sir it as a common problem in line printer. You need to do paper out calibration in the following ....
1)Press menu button and select test menu with the help of up down arrow & press enter.
2)Select Diag menu & press enter.
3)Select Cal paper - press enter and follow the instruction which will come on the display of the printer control pannel.
when you will finish the calibration press clear & take print out.
If not solved hold lf+enter and go to diag and select PAPTHOLD & increase the value up to 250 and press enter.Then go to the config menu and select configuration & press two times enter to save the value. Press clear button & take print out online. In this way you can solve the problem.
Apr 10, 2014 | Office Equipment & Supplies
My printer has started printing a black line down the edge of the paper?
Remove the laser print cartridge, shake it lightly, and place it back into your printer. That should solve the problem.
Mar 15, 2013 | Kyocera FS-1030D Laser Printer
When I print on regular paper, the color prints look fine. When I print on photo paper, I get a consistent quarter-inch vertical orange line on the prints and the colors look washed out. Time for new...
Hi
Basics first (which you may have already considered).
Explore the Canon Printer software settings.
You need to adjust the Printing Preferences when switching from paper printing to photo paper printing.
Also look at the Print quality and colour saturation settings and try to print in Fine or High Quality when printing on photo paper
If none of the solve the problem, check if something is not stuck in the paper input tray and pressing the photo paper to close agasinst the scanner.
Make sure the paper is properly centered and cradled with the addjusble paper guide on the In Tray.
If tall new none of this works, install new cartridges and conduct Nozzle Check and Print Head Cleaning maintenance and then test print again.
I hope this helps.
Aug 24, 2011 | Canon PIXMA MP510 All-In-One InkJet...
One default vertical line is printing in the right side of the printable area on the printed paper
i have hp printer laser 1505, it can print out and i set the paper on portrait. but the output of printing out is the characters are on landscape style. So what should i do...plz help me if somebody can solve it
Sep 03, 2010 | HP LaserJet P1505n Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Unable to do a reverse line feed
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
May 29, 2008 | HP LaserJet 4000tn Printer
Epson Lx300+ printing problem
hi
pls check printer test print
  1. switch off the printer .
  2. insert paper in printer
  3. hold the button ll/ff pressing .
  4. switch on the printer
if you get test print OK then. you need to be Reinstall Printer Drivers on your Pc
May 22, 2008 | Epson LX-300 Matrix Printer
Paper Thickness Lever
there is a part we could it mask its piece of metal in front of the head clean if the problem dos not solved tray to change
Mar 22, 2008 | Epson LQ-2180 Dot Matrix Printer
HP PSC 2355 Truncated lines
Try cleaning the paper rollers and the print head.
Use a wet cloth to clean the paper rollers.
Use a little amount of water and some alcohol (Isopropyl alcohol) to clean the print head. (You may not need to do this if your printer cleans it automatically through software utility.
This may be also have caused by the low ink level. Replacing the cartridge should solve this problem.
Oct 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP LaserJet P2015dn Printer Logo
124 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
