Question about Gateway MX6454 Notebook PC
Gateway Mt-6733 For some reason I cant use my wifi connection, or bluetooth connection, I push fn - f2 key for the blue light looks like a antenna... nothing works, can you help me..
  • hcsr
    hcsr May 11, 2010
    Have a look at your noetwork connections and make sure your card is not disabled..
    or go into your device manager uninstall it and restart your laptop and is should self install it self and start working
How do i get wifi on my laptop?
On laptops without a dedicated WIFI power button, usually the wifi is turned on via a Hot Key. Look at the FUNCTION keys on the laptop. Are there any BLUE symbols there? If so, these are Hot Keys. One of them should look like an antenna (or a magic wand!). Press and hold the FN keys (down next to the WINDOWS key), and press the Hot Key. These keys work on a toggle-on, toggle-off basis. Once is it on, do it again to turn it off. Once you've tried this, look for the WIFI indicator light to be lit.
Mar 02, 2015 | Systemax Computers & Internet
I cant see the wifi button
It's a keyboard combination -- have a look for an antenna symbol printed on F2 -- then press the Fn key while pressing the marked key.
Hope this Helps:)
Please Rate and Thanks!
Gary
Aug 27, 2013 | Dell Latitude D600 Notebook
2nd question please, Dell Inspirion lost wireless connection, troubleshooter shows device turned off.
try this
look for the FN button at the buttom left push it down and hold it
look at the top look for f2 it should also have an antenna on it push it along with the fn button
this will turn on ur wifi you should also see a green light come on near power button
good luck
Oct 12, 2011 | Computers & Internet
Wheer is the wirless switch on a inspiron 1545 laptpo
It is not a switch
look on the keyboard and look at 'F2' button and press it
this is the button which turns on the wifi
note the f2 key says f2 in blue and then shows a wifi signal icon in white also note a blue square box appears as you switch on and off your wifi connection in the bottom right hand corner...
Jun 01, 2011 | Dell Inspiron 1545 Notebook
Where is the wireless switch on a Acer Aspire 5735
Usually, if there is no HARD SWITCH for wifi, there is an equivalent keyboard key combination to turn wifi radio receiver ON. Look at your laptop's Function Keys: F1, F2, ... F12. Among them there is an icon for WIFI, something that looks like an antenna with wave signals. Now press and hold the FN key and press that function key with the wifi icon. Example, if the wifi icon appears at F10, then press FN + F10 to turn your wifi ON or OFF.
Nov 17, 2009 | Acer Aspire 5735 Notebook
Can figure out how to turn on my blue tooth functions on my dell m6400
If you have the Bluetooth option installed on your laptop press Fn+F2 and that should enable bluetooth.
Aug 31, 2009 | Dell Mobile Precision M6400 Notebook
FN F2 to turn on wireless not working.
check it isnt disabled in the BIOS settings
Mar 12, 2009 | Gateway M680XL PC Notebook
Hardware switch on a amilo fujitsu laptop
On some of the Amilo Models, the Wi-Fi button is actually a key combination on the keyboard. Have a look for a key with the wireless symbol on it - looks a bit like an antenna, and hold Fn while you press that key. Your Wireless should come back on.
Fujitsu's can be odd, cause the hardware button (mentioned above) doesn't actually disable the driver in Windows, just turns it off so no connections appear.
Mar 05, 2009 | Computers & Internet
Wireless networking
the key combo is F2 + Fn key (the fn key is located on the bottom row all the to the left) a little blue light lights up that looks like this ((o)) that lets you know it's on. press the combo again to turn of wifi communications.
Nov 15, 2008 | Gateway 7330GZ Notebook
Broadcom 802.11g stop recognizing any wireless on my gateway laptop
is this on a laptop? check that the wifi is not turned off. some laptops have a switch on the side or perhaps a Fn key (blue icons on the F keys) that disables the wifi on the pc. try Fn+F2 or Fn +F5 (look a the F keys for a blue wifi icon)
post back results and the system you are using inc the OS so I may assist in greater detail if required
Jul 21, 2008 | Broadcom Computers & Internet
Gateway MX6454 Notebook PC Logo
104 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
