Question about Sony DAV-BC150 System
Sony DVD Home Theatre system disc won't eject
Says reading then gives error code. Disc won't eject, can't open tray. Model DAV-BC150/BC250. Is there a manual eject method?
SOURCE: Sony DAV-BC150
Sounds like your TV's sound output isn't working. Check all the connections and if that doesn't do it, try hooking up some other sound system to the TV to check that it is working properly.
Posted on Aug 20, 2008
tc3gs400
  • 14 Answers
SOURCE: how to play multi region disc in sony hometheatre dav-dz280
your player comes as a multi reader player..
Posted on Jan 12, 2010
SOURCE: i can not eject the disc tray
I too had a similar problem with my DHC FL7D. The front moving panel would not move up. The screen used to say 'please wait' endlessly whenever I pressed the DVD button. I thought the drive belt might have got cut. There is a drive belt for the front panel to move upwards and downwards. Since that was intact, I disconnected the front panel from the main body to access the DVD drive system. I had to disconnect many cables and PCBs to do so. Then I opened the DVD compartment and removed all the DVDs which were stuck and re-alligned all the disc trays to its original state. I checked if all the drive belts inside the DVD compartment, it was ok. Also I tried moving the laser lens assembly to check if it was moving. Since there was no problem I closed the system. <br />After I switched on it worked again . I think it might be to do with the fact that the disc trays might have been stuck for some reason or may be the there was a software glitch.<br />
Posted on Aug 20, 2010
SOURCE: DAV-FX900W System: DAV HDX576WF is throwing an error "C 31 00" and no...
I had a problem similar problem with a dav LF1. I undid a couple of screws, poped the top of the CD/DVD drive so I could them pull the disk out by hand. I then prised the slot open a bit more with my fingers and the plastic eject arm poped up, it seems it was stuck. Works fine now.
Posted on Dec 18, 2010
welcomejee
  • 10594 Answers
SOURCE: I have a Sony DAV-880 home surround system and a
Press Eject and Stop buttons on unit at same time for 4 seconds, display will show Unlocked, now you can eject discs.
Thanks.
Posted on Dec 28, 2010
Testimonial: "Superb information, worked just great, thank you so much for this, very impressed."
My Sony Home thatre system DAV-DZ10 give a message : No Disk. How to solve that problem? Any help?
All DVD players will say no disc if there is no disc in the drive when closed. If however it does so when there is a disc in the drive, plus the disc is clean and undamaged, then you have a problem. It could be caused by dirt on the lens, but since it was doing funny things before there might be an electronics issue. I would still clean the lens first.
Jul 05, 2015 | Sony Dav-dz100 Home Theatre System
Sony dav-dz555k home theatre system-dvd tray keeps opening and closing, wont read disc at all. have to manually push tray closed and change setting from dvd to something else to stop it.
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Mar 14, 2011 | Sony Audio Players & Recorders
ERROR CODE C 13 71 ON SONY HOME THEATRE SYSTEM, DAV-F200, SON PUT MORE THAN ONE DISC IN AND THEY GOT STUCK!!
I have a home theater system - Sony DAV - IS 50, I purchased in the U.S. about one month ago, which works at 110 V and has a power 130 W
I use it in Bulgaria, where the voltage is 230 V electrical networks linking it with a transformer 220 VAC - 110 VAC - Power 200
The
brand of the transformer is THG-200 S Goldsourco.
In DVD mode when inserting a disc - DVD-R disc is ejected and the display code C: 13:71 and the inscription "The disc is dirty". I use brand new discs, but all over again. I do not know what the problem - please help me.
Jan 29, 2011 | Televison & Video
Hi I have Sony DAV-DZ270 DVD Home Theatre System HDMI, Model. but it can't play (read) movies on my memorystick.Can only play movies that is copy on DVD recorable disc
i have sony DAV-DZ270 DVD player but its cant play i write these cd .only play movies wherever i m byiung from market.
Jan 09, 2011 | Computers & Internet
CD tray automatically opens, when entered, cd not readable
Please clean tray loading section and specially loading belt. This cleaning will required to apart unit. If you are familiar with such kind of job, go ahead or ask help of local tech.
Jan 11, 2009 | Sony DAV-S300 System
C:13:71 error on my DAV IS10 SONY home theatre
I think it is a dvd laser failure My Sony HT gave that error when it couldnt read discs , its most likely a failed laser (DVD player in one of those home theatre in a box)
Oct 07, 2008 | Sony DAV-IS10 System
NO DISC ERROR on DAV-BC150
Given how close to the warranty termination the problem occurred, I would call Sony and request warranty service. You should speak to a supervisor who will have the power to grant that concession. If that fails, open up the unit and clean the lens using a cotton swab and alcohol. That may resolve it. Otherwise, the optics assembly will need to be replaced. I think that model uses a KHS-240. I can look that up if it comes to that though.
Keep us posted.
Dan
Apr 16, 2008 | Sony DAV-BC150 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
Mar 20, 2008 | Sony DAV-BC150 System
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
Sony DAV-BC150 System Logo
188 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
