Question about Samsung SyncMaster 540N 15" LCD Monitor
My monitor's power bulb flicks or turns on but the monitor displays nothing,yet it is correctly connected to the computer.
    Problem Solver:
  • 12 Answers
Hi..!
Check your system RAM or memory..
Amit..
Posted on Feb 20, 2009
Viewsonic VX2640W was running with the screensaver on,then suddenly went solid white. Turned off for thirty minutes then back on with same result. Unplugged from computer and turned on. Still turn
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Feb 03, 2014 | ViewSonic VX2640w LCD Monitor
Monitor will not turn on
Monitor will not turn on as in NO Power? When you hit the Power Button the monitor power light does not come on? If so either the power cord is not plugged in good, maybe the outlet you have it plugged into the wall or power strip is not working, or the Monitor is bad and needs to be replaced.
If you are saying the monitor has power but the display is black then:
Look to see if it sounds like the computer is running but nothing is shown on the screen. If so try this:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 06, 2012 | Toshiba Satellite P35-S611 Notebook
Screen is black, shows no image. Sometimes it flicks and sometimes presents a lot of horizontal colored lines. Once or twice the screen worked for a couple of seconds, saw the windows' logo and then it...
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Feb 08, 2011 | Toshiba Satellite L305-S5875 Notebook
When I power up my monitor the display briefly flashes on - to the login screen - and then the display goes blank. If I use the power switch to turn the screen on and off the same thing happens - brief...
Open the monitor, look for blown capacitors and replace them. If problem persist, test the light bulbs and the inverter. If the inverter includes ceramic capacitor, replace it. If some of the bulbs does not do the flash - replace it. Check the transistors of the inverter. Replace if faulty.
Aug 07, 2010 | Dell Computers & Internet
When i connect my projector to computer correctly it says no signal
Please perform thebelow steps :
You may follow these steps to connect the notebook to an Projector
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
Projector
May 20, 2010 | Computers & Internet
Power stable however no display, the lock keys flick and the bluetooth symbol always on.
no display after switching on the laptop?
1. try to connect to an external monitor using an analog video cable. monitor is on. turn on laptop after a minute press and hold on Fn key then press F8 at the same time to toggle the display between LCD to Monitor, if nothing happened do step 2.
2. turn of laptop. remove video cable. press and hold D key then press power button at the same time. this will test the LCD. check if there are colors display. if yes do step 3, if no replace lcd and lcd cable.
3. make sure laptop is off. press and hold on the Fn key then press power button at the same time to run a quick test. Even no display or anything wait for about 5 minutes check if you will hear series of beeps. If yes.replace video card if it is expansion, replace motherboard if it is integrated.
Sep 24, 2009 | Dell Vostro 1510 Laptop
Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
May 21, 2009 | ViewSonic VG2230WM LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Samsung SyncMaster 540N 15" LCD Monitor Logo
73 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
