Question about Sony PlayStation Portable (PSP) Console
Psp not reading - Sony PlayStation Portable (PSP) Console
  • 67 Answers
Only thing you can do is try cleaning the lens. there is on you can reach by q tip with a little rubbing alcohol. any thing else requires dissasembly. if you want to do this you will need to remove the face plate four screws on the back 2 on the right 2 on the left under battery and warrenty sticker one las screw on the silver trim rig @ bottom of lcd once plate is removed you will need to remove the lcd screen this is done by first undoing the menu bar/volume control buttons use a small flat head screw driver pick one side left is prefered and slide the bar off will require small pressure. then take the flat head screw driver and wedge on the left side between the lcd mount and lcd and twistpushing the lcd in and up once one tab is released go to the top side and repeat process once 2 tabs are up on one side you can pull the lcd out a little adhessive may have glued the lcd to the mount just pull lightly til the adhessive gives at this point you can either remove the electrical ribbon form the menu bar and the lcd the flaps for the lcd pop on the top for the small ribon and bottom for the big ribbon and the menu bar flips from the top with those out of the way you will want to undo the bottom right screw not attached to the lcd mount then on the bottom left of the lcd mount there are 3 screws next to each other undo the middle one these 2 screws lock the umd door on now flip over psp use flat head on bottom left side same concept as lcd put pressure in towards umd and out once tap is out other side should work out do not twist too much. once outside cover is off remove metal umd frame just open as normal and look at hinge there is a tab limiting motion just push tab and complete open motion then slide tray off hinge tabs if you see dirt dust on any part of the laser clean it. there is also a refration glass make sure it is clean as well there is also the laser reciever/transmiter if you wish to clean this you may have to remove drive remove 4 screws and 2 ribons ribbon going right left is a slide clasp . once all is clean just put back together make sure on umd cover you get the eject spring in the umd cover guide or umd cover will not close. If you don't wish to try this yourself email me @neo2123@cox.net we could arrange a repair if in the U.S. if umd drive is just dirty I'd only charge 10$ if its bad I'd only add parts charge which last time i checked on e bay is usually 10$ plus shipping of corse.
Posted on May 26, 2009
    Problem Solver:
  • 7 Answers
Your UMD laser needs to be replaced.
Posted on May 24, 2009
  • 26 Answers
The memory card is not inserted well.
Posted on Apr 03, 2009
I want to download music from my computer to my PSP handheld
well all you need to do is connect your psp to the computer and put the music int your music folder. NOTE: the psp can only read from one folder in so you can't put a music folder into a music folder and then put it into the psp music folder. ex: psp > music > u2 > vertigo > Song = can't read; psp > music > u2 > song = can read.
May 18, 2010 | Video Game Consoles & Games
My psp can't read MS , i don't know why, the
format the memory stick with the psp instead of a computer.
May 13, 2010 | Sony PlayStation Portable (PSP) Console
No source will read my memory stick pro duo mark 2
  1. Try re-formatting your memory stick from your PSP console. A memory stick that is formatted from a PC or other hand held console sometimes cause incompatibility problem with the PSP.
  2. If your PSP still can not read the memory stick, try checking your memory stick by using your friends PSP and see if they can access the memory stick.
  3. If the memory stick can be accessed by your friends PSP then there is a problem with the memory slot of your PSP.
  4. The only way to check the contacts of the memory slot of your PSP is to disassemble you PSP and take out the mother board.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
I have psp 3000 v5.03 my psp can't read any game last night its work but next morning it can't read any game.when i open the memory stick, it say "there are no game" when i plug it into pc, the game...
dude make sure that ur psp has chick=hen running then after that run gen a CFW to see ur ISOs aka psp games,
if you are runnign chickhen and gen a, your psp will have to run both programs again when you turn it off completely
Dec 31, 2009 | Sony PlayStation Portable (PSP) Console
Psp slim dosent read umds dono whats wrong makes a little noise
it might be that your lens that reads the psp is dirty so it cant read them
May 28, 2009 | Sony PlayStation Portable (PSP) Console
Ghost Folder PSP FOLDER Cannot READ PLEASE HELP
For the PSP to recognize the folder, it has to be in all capital letters.
Ex: UPDATE or GHOST
Feb 19, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp memory reading?
It might be that the SD card's format isn't right for the psp to read, if you have a psp usb cable you might be able to change the sd card to the right format via CPU.
Jan 31, 2009 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
141 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
