Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
Problem in pc
Whenever i try to disconnect my pendrive by clicking the icon on the task bar and further clicking on samely remove the device. then it shoes that cannot remove the device now, try later always what's the problem with that?
  1. Either your system is affected by a virus.
  2. The programme may be running (using pendrive)
Solution:
  1. Insert the pendrive and without opening it got to -my computer-pendrive-right click-format-format as FAT-start. After the pendrive is formatted remove it safely.
  2. If the problem persists then u will have to format ur system for any virus contained.
  3. This will 100% solve ur problem.
Bye
Posted on Feb 20, 2009
    Problem Solver:
  • 12 Answers
Hi..!
Your pendrive can be infected by any virus or trojan..
Scan it with a good antivirus..
Amit
I hv. pressed and opened the kingston 4gb dell pendrive now m nt able 2 close it.
make sure there is no application using it. sometimes there might be some process using it but not showing up on task bar or systray. you can use task manager to kill those process if you can find them. you can also open the USB device box by double clicking on the USB device icon in systray and then select the top usb device and click on the close button, or try the drive letters in that box if the first approach does not work. or you can try open device manager and remove the USB devices from there if necessary.
Jun 08, 2011 | Computers & Internet
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
I am looking for kingston service centre in new delhi because my pendrive of kingston company not working.
Apr 09, 2011 | Cell Phones
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a 2GB scandisk pendrive, I unable to format it, Whenever i tried to format it in command. Msg appered IOCTL call error. how can I format it. Pl help me
Try formatting the flash drive using this method.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 22, 2009 | Transcend (589307) Media
Task bar displays
Just right click the task bar and click properties and then click customize , then click restore default Over!!!!
Aug 22, 2009 | Microsoft Windows XP Professional SP2 Full...
Internet is disconnected
If your LAN connection is on the Task Bar the right click on this Icon and left click on REPAIR.
If no Icon on Task Bar the click on Control Panel - Network Connections - then right click on your LAN Connection and left click on REPAIR.
Apr 19, 2009 | Acer Aspire 5315 Notebook
Sandisk 4GB pendirve not recognised by PC - Driver issue?
Dear Friend,
I have problem in my pen drive which which built by SAN Disk its storage capacity in 4 GB i am using winxp but this pendrive is not recognize by OS pls solve my problem
Thanks
Aug 09, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Correct way to remove drive from notebook with vista
When removing the prn drive from any system go to task bar select the pendrive icon select the option " Remove the drive safely " after that pen drive light is off then it will remove it
Are do this way
Go to Mycomputer select the pendrive icon right click select the option is " Remove safely the drive " then pend drive light off then it remove
Jun 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Wireless router disconnects every 5 minutes...
I had the same problem with my dlink (not wireless). Try going to their website and configure the router. It worked to me.
Dec 07, 2007 | Linksys Wireless-G WRT54G Router
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
