My SyncMaster 152v monitor was turned on and the screen was black
I came home one day booted my computer and the monitor never worked again. The screen is black I tried to lighten the settings but it did nothing. Oh yeah. the menu would pop up when I tried to adust the screen but otherwise it showed nothing.
Is a fuse or something I can fix?
5 Suggested Answers
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
SOURCE: HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Posted on Nov 09, 2009
Starworx
  • 4 Answers
SOURCE: my monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Posted on Dec 17, 2009
  • 38 Answers
SOURCE: syncmaster 152v repeatedly pops auto
You could have a stuck button on the monitor. Or there could be something wrong with your computer's display settings. Depending on the aspect ratio of your monitor (4:3 or 16:9), will depend on which resolution will be appropriate.
Check this for more info:
http://en.wikipedia.org/wiki/Display_resolution
http://en.wikipedia.org/wiki/File:Vector_Video_Standards2.svg
If your display is a 4:3 aspect ratio, you should choose a red set of dimensions. If your display is a 16:9 aspect ratio, you should choose a blue set of dimensions, etc.
Posted on Nov 28, 2010
Hi, i own samsung syncmaster 740n Monitor, from last 5 days, black horizontal lines are appearing on screen.today it is work.black shaded lines are becoming more worst .. what could be the cause, ...
We need to narrown down the causes first by trying this monitor with a good working PC to make sure it is not monitor problem, we do not want to open uip the monitor unless we have to.
Post back what you find, if it is monitor problem then please read below:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 08, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Syncmaster 226CW showing picture only for a second + flickering
Call and get the RMA for your monitor, the problem is in the power supply and it will only get worse. This is a common problem with LCD monitors after 2-3 years of use.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Black screen and a blinking green led..
Have you tried booting the machine into safe mode? turn off the pc and try inserting a rescue boot disc to see if it will go that route.
Aug 27, 2009 | Samsung SyncMaster 244T Monitor
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
Monitor to black, power LED blinks, hard re-boot and it works
Take a look at your power saving settings. It sounds like the monitor is set to sleep after 20 or 30 minutes. You may want to change your setting to "never". The settings are under Control Panel - Power management
Aug 15, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
My monitor is a SyncMaster 2220WM... the othe day
Your INVERTER has crapped out. Look on ebay.
Jun 26, 2009 | Computers & Internet
Screen won't come on
  1. Check video card
  2. check cables
All else fails and you do not even got a standby light you might have a blow power supply in this monitor $40 bucks to fix if that is the case as that is what mine cost.
May 25, 2009 | Samsung SyncMaster 932GW LCD Monitor
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
