Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Formating raw usb flash disk
Is there a way to format a raw usb flash dirve? formating it from windows failed
  • Zarel Tgr May 11, 2010
    Wow... I've never experienced a raw USB drive (no fomatting whatsoever) before. Did you get it out of the package like this? If so, I would certainly seek an exchange. For Sandisk Cruzers, that's certainly not normal... not only is it FAT formatted, but there's also a CDFS-formatted section with U3 fluff (which I typically nuke straightaway with the Sandisk U3 Removal Tool)
    So, for clarification, was it raw 'out-of-the-box' or did that happen due to later actions?
  • VonZeppelen
    VonZeppelen May 11, 2010
    When you formatted, did you try FAT or FAT32? Also did you try quick Format option?
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
Transcend jet flash v33
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Mar 30, 2014 | Electronics - Others
Convert usb raw drive to fat drive
The Fat32 (FAT) format is used to format disk drives on Windows-based computers and can also be recognized by the Mac's OS X operating system. You can format a flash drive with the FAT format so that it can be used on both PCs and Macs. The procedure is straightforward, if different depending upon the operating system being used to do the formatting. You do not need to purchase any additional software to format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory b> http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html Format USB flash drives with FAT, FAT32, or NTFS partition types. Plug the Flash drive into a USB port on the Mac. Double-click the "Applications" folder inside of the Mac's hard drive. Scroll down to the "Utilities" folder. Double-click the "Utilities" folder. Scroll down to the Disk Utility program. Double-click on the Disk Utility program to launch it. Click once on the icon of the Flash drive that is in the left column of the Disk Utility program's main screen. Click on the "Erase" tab at the top of the window of the Disk Utility program's main screen. Name the Flash drive in the "Name" column at the center of the Disk Utility program's main screen. Select "MSDOS (FAT) from the "Format" menu beneath "Name." Click the "Erase" button at the lower right corner of the Disk Utility program's main screen. Click the "Erase" button in the pop-up confirmation window that appears. Wait as a progress bar at the bottom of the Disk Utility program's main screen fills in from left to right. Click the "Eject" button at the top of the Disk Utility program's main screen once the progress bar is completely filled in. Quit the Disk Utility program. Remove the Flash drive from the USB port of the Mac. b> Format Flash Drive in FAT on a PC b> Plug the Flash drive into a USB port on the PC. Go to "start," "My Computer." Right-click on the icon of the Flash drive in the center column of the window that appears below "Devices with Removable Storage." Select "Format" from the pop-up menu. Select "FAT32" from the "File System" drop-down menu in the window that appears. Click the "Start" button at the bottom of the window. Click the "OK" button in the confirmation pop-up window that appears. Wait as a progress bar fills in from left to right at the bottom of the window where you had selected "Fat32." Click the "OK" button on the "Format Complete" pop-up window when it appears. Right-click on the icon of the Flash drive that is on the desktop. Select "Erase" from the pop-up menu. Remove the Flash drive from the USB port of the PC. Hope this helps.
b>
Dec 07, 2012 | Corsair Memory Computers & Internet
Hard Drive RAW System
Run diagnostics on the drive it may be failing. If it's ok you can try to reformat it from Windows Disk Management.
Or if you need to recover data for remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 11, 2012 | FireLite (USBFLB80) Hard Drive
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
My pen drive is in RAW file system, I ca'nt open or format it.
Try to get a software called parted magic. its linux based and you should easily format the pen drive.
U can also try HP USB Disk Format Tool.
May 28, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My Verbatim 4gig store and go usb stick in stuck in RAW Format
right click my computer, manage. go to disk management and delete any volumes on the flash and set back to basic disk if it's dynamic. format fat 32
Mar 14, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I want to convert USB Sticks in RAW to FAT 32 (they were received faulty, they shoulf hasve been fat 32 but were received in raw)
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format USB Stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 24, 2010 | Electronics - Others
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
RAW FS TO FAT 32
i recently bought a sony flash drive SSK/2GB.however the same is not working at all as it is showing RAW file system instead of FAT 32 .neither it is getting formatted nor allowing anything else to b doneto it.
Nov 11, 2007 | Electronics - Others
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
1,670 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
