Question about InFocus X1 Multimedia Projector
?blown bulb My infocus x1 has much less than 3000 hrs but has a fixed image of a shower of lit pixels to left of screen and nothing works off the remote. Is the bulb gone? Cheers for any help...
Check at the modding tab. they will show you how to bypass the ballast and how to rebiud the lightbulb whit 50 bucks or less. good luck web site in frech, use traductor to understand it, is full of imagens anyway.
Posted on Oct 20, 2009
  • 2,237 Answers
Do you hear a high pitched whir or chirping? the whir is normal. the chirping is the colorwheel not syncing with the dmd chip. this will cause that image distortion. if the colorwheel is fine, then it's the dmd chip of the chip pcb that needs reseating or replacing.
Posted on Sep 04, 2009
Model x1. Why does picture have white spots at the top of the screen?
If the projector is a DLP then it will probably be the DMD chip. The white spots are caused by damaged pixels.
Jan 28, 2016 | InFocus Office Equipment & Supplies
The bulb works but I can't get an image
is the projecting image black or what??
what is being projected actually??
have you checked the lens section?
Aug 11, 2008 | Apple InFocus X1 Multimedia Projector
Black and white specks from InFocus X1 projector
if you can get a menu when you press the menu button, reset the settings to factory default. if you don't get a menu, the color wheel or the dmd chip is bad. either way, you'll have to replace the entire optical engine. and unfortunately, infocus no longer has any more in stock.
Sep 06, 2009 | InFocus X1 Multimedia Projector
The bulb on X1 blew out, I replaced the bulb, the
it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
Aug 10, 2009 | InFocus X1 Multimedia Projector
INfocus X1 does nothing after bulb replacement
first off, make sur you have the right lamp (sp-lamp-009, 2 white wires. not the sp-lamp-018, one white, one red. the wires are in different locations in the plug). if you don't hear the colorwheel whirring, that'd be the next step. however, you cannot buy just the colorwheel. infocus does not sell individual parts of the optical engine. but that wouldn't matter, seeing as how they don't sell the engine anymore. also make sure the lamp door is completely closed. there is a peg on it that activates a switch to let the projector know it's closed. if you remove the lamp and use a flat-head screwdriver to activate that switch, turn on the projector. look inside the lamp housing and see if the colorwheel spins. if not, i think you need a new projector. if it does, check the fans. they can be replaced.
Dec 19, 2008 | Apple InFocus X1 Multimedia Projector
Your comments
you need to replace the controller eca (main board)
Aug 13, 2008 | Apple InFocus X1 Multimedia Projector
Apple InFocus X1
It seems like your main card is not functioning.
pls check :
1. Color wheel is rotating or not.
2. Recheck Main card connectors.
mail me for any changes
Jul 16, 2008 | Apple InFocus X1 Multimedia Projector
Infocus SP 4805
How old is it ? Approx how many hrs have you used it? Was it set at Lo speed / low power or hi speed / max power on bulb and fan? Do you smoke in the same room? Is the unit ceiling mounted ( more concentrated hot air ). Have you had a power failure while the unit was on? The bulbs used in many projectors , although claiming 3000 or more Hrs ,are subject to early failure. If the unit or bulb is new ( less than 1 yr. old, contact the service manager at that co. and complain about short life; IThat works !
Apr 30, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
InFocus X1 Multimedia Projector Logo
171 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
