Question about Compaq SYSTEM BOARD PRESARIO 1900XL (174104001) Motherboard
I have a problem, in short. I took my Compaq Presario apart to disconnect the internal battery, replace the faulty 3.5'' disk drive, & too check to see if their was a possibility that through out all the parts & peices that I've managed to aquior for laptops/notebooks/etc. I was hopping and preying that I would get lucky enough to replace the battery cord, if not the battery itself. Even after taping the loose peices down so that I could turn and move the botton around to unscrew, and view what I was going to be removing to replace back together. I had some parts DROP OUT! I cannot find where they could/would possibly go; the one part bothering me most, is the FUSE; why, and ''WHERE'' could this possibly go??? I also have Older PCs too which I am ''playing'' with,it would be nice to know what parts I'm looking at, & where they go; Not too mention some sort/kind of discription! Tech Spec's, Map/ Manual...??? Please Help!
  • Compaq Master
  • 5,660 Answers
I'd like you to take a deep breath, and relax. Everything is going to be alright. You're in my world now, and this is old hat.
First of all I would like to give you a link to the Service Manual for your laptop. (It's free from HP Support. {HP bought out Compaq a long time ago)
HP Support > Compaq Presario 1900XL-1 > Manuals,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=95453&#
Scroll down to -
Model XL1-XL165 - Maintenance & Service Guide Presario 1900 Series,
and Left-click on it.
[This Service Manual encompasses the Presario 1900XL series, from the XL-1 to the XL-165]
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would advise at least having Adobe Reader 8, but the new 9 version is the best. You can download for free from Adobe)
There is a way to save this file to your computer.
This way you can burn the Service Manual to a CD disk, and remove it from your computer to give your harddrive more space.
If you are not aware of how to do this, I will be glad to guide you.
You may be aware of the following, but I feel obliged to detail it.
Before taking any computer apart, (Desktop or Laptop), you should follow Anti-Static Precautions.
I use a cheap ESD wrist strap, and connect the alligator clip to the metal frame, of an empty desktop computer's case.
This is an example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
I would use a multi-compartment container, to put the various screws in.
There are Many screws, and many of them look alike, but are not.
The compartments should be labeled for where the screws came from.
You can use a clean egg carton in a pinch.
I would suggest now that you disassemble the entire laptop, except for the LCD Display.
If there is just one screw laying against a circuit trace on the motherboard, or a solder joint, it can cause a direct short.
(Short circuit = fry out)
Shot my mouth off apparently, as I'm not aware of a fuse for this model, and the Service Manual shows nothing.
I would check the Converter Board, (Page 62)
The Converter Board is where the AC adapter (Charger) plugs in.
Now, let's talk about those older PC's.
(Post back in a Comment)
Posted on Aug 01, 2010
  • 134 Answers
Em first you should have consulted your local pc operator.Atleast you would have him responsible for that but right know you have to see any i am pretty sure they can help.
Posted on Jul 08, 2009
Compaq presario v6000 computer does not detect hard drive storage
The hard disk may be faulty or it just needs reseating to make proper connection.
Reseat the hard drive and boot up your laptop. If it does not boot up then go into the BIOS configuration to see if the BIOS detects the hard drive.
If the BIOS deos not detect the hard drive then most likely it is faulty. In this case to get your laptop working again, replace the hard drive and install Windows on the new hard drive plus the Presario's device drivers and your programs.
Jun 21, 2011 | Compaq Presario Notebook
My compaq presario x-1000 hard drive light and dvd rom light flashes. Won't boot up.
Try disconnecting the harddrive from the case and then place it back in. if that doesn't help you may have a faulty drive, hows warranty? Compaq / HP would fix it for you free if you still have warranty.
let me know.
Thanks,
Ekse
Oct 31, 2008 | Compaq Presario X1000 Notebook
My compaq presario c700 will not boot and it's saying that there is no bootable device, insert boot disk and press any key, however, i do not have a boot disk
Your Compaq did not detect the hard disk, that is why it is asking for a bootable device such as a boot floppy disk.
Check the BIOS configuration to see if the hard disk is detected, if not then re-seat the hard drive and boot up the Compaq again.
If it still does not boot up, then the hard disk is probably faulty.
To get the Compaq operating again, replace the faulty, install Windows operating system on the new hard drive, plus the Compaq's device drivers and your programs.
Jan 09, 2011 | Computers & Internet
I have a Compaq Presario 2715US. Started having
The problem maybe a loose electrical connection with the RAM modules and hard disk. Re-seat the RAM modules and the hard disk.
If the problem persists then the hard disk maybe faulty.
To test the hard disk, remove the hard disk and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer has trouble seeing it as an external hard drive and unable to open the folders and files then the hard disk is faulty.
Then the hard disk needs to be replaced in the Compaq and Windows XP needs to installed on the new hard drive and the device drivers and programs.
Oct 12, 2009 | Compaq Presario 2715US Notebook
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
Compaq Presario V5000 has very choopy sound
Try external speakers. If they work, the soundcard is OK.
Aug 22, 2009 | HP Compaq Presario V5000Z Notebook
Compaq 701tu cd drive does not spin
check if the green light comes on when you insert a disk,if no?
1. switch off the pc,
2. open the case cover
3. check the power cable is connected to the device"compaq 701tu cd drive"
4. if still not working
5.try other cd device and if that work,it means your compaq 701tu cd drive is faulty and to be replace.
Jul 31, 2009 | Sony CDU 701 (CDU701-10) Internal 32x...
Compaq Presario F700 Laptop power up issue
Remove your cpu/gpu heatsink, apply a ermal bonding, this will prevent shut off because of cpu/gpu overheating(chipset detects temperature faulty in the firsts seconds of operating your laptop), if this didnt resolve your problem, naybe and issue with your Mobo.
Thanks
Please leave feedback
vcrtech
Apr 27, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
Batery light blinking
try rundown the battery 3 times if still not holding charge your battery is faulty you have to replace it.
regards
Richard
Jan 28, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
73 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
