Question about JVC GR-DVF31U Digital Cybercam GRDVF31U Camcorder
Camera gives message E04. What can I do?
A problem just started. When I turn on the camera to start recording, a message appears on the screen....EO4.
The camera will perform any functions....except turn on and I can switch to different modes....as in A or M.
The camera still does not work.
What should I do/
Sounds crazy, but It worked for me. I open up the tape door, ejected the tape. lightly squeezed the two long sides of the piece that hold the tape in place. I placed the tape back in. The tape fit slightly more snug in the cassette holder.
This worked for me.
Posted on Mar 20, 2009
Can't get started
Could it be that the SD card is not fast enough? I think that SD 40x or SDHC class 6 is needed from my experience (I am not sure what it says in the manual). What speed/class is the card you are using? I get these sort of problems intermittently on my HD2 (the predcessor to the HD1000) when I use a slower card.
Dec 30, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Was recording fine then message to check disc when turned back on
Unless you've been unlucky and had two bad discs in a row its probably the camera. have you tried resetting the camera and trying again?
Jul 13, 2008 | Panasonic VDR-D100 DVD Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Broken video management file/ recording failure
Although the instructions don’t make it clear, it seems to be important that the camera is turned off before you connect or disconnect the USB cable. The instructions do mention that you should not delete or rename files on the camera except in the EXT_MOV folder. The camera’s firmware is apparently quite fragile about file names and the presence of the extra hidden folders that both the Windows and Macintosh operating systems create when you delete something.
Apr 07, 2008 | JVC Everio GZ-MG37 Camcorder
Lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Dec 31, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
May 05, 2007 | Konica Minolta DiMAGE S414 Digital Camera
E04 message
Lisa, E04 is an error code which shows that one or both of the reels has stopped during play or record operation. We find that tapes with liquid contamination can stick to internal parts in the mechanism causing this error. Try another tape, if this does not resolve the problem something is defective in the tape transport. Good Luck to you! Joe Weibel customelectronics.org
Feb 09, 2007 | JVC GR-DVM70 Mini DV Digital Camcorder
When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the LCD monitor.
Please follow the procedure below: 1. While the message is displayed, press the center of the controller. 2. The LCD monitor and data panel will turn off . 3. Turn the Main Switch to OFF and remove the CompactFlash card from the camera. 4. If "No Card " message appears at next time the camera is activated in the recording mode, the camera and CompactFlash card are OK. 5. In case that "Card Error. OK" appears again, the CompactFlash card may be faulty. Use other card.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Video Cameras Logo
173 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
