Question about HP Pavilion dv1000 Notebook
My laptop does not detect/respond to LAN conection
    President:
  • 1,223 Answers
Try pinging it with utility or google network diagnostic tools , are u using the correct cable , i mean is it straight or cross coupled or which devices u are tryin to connect , see the driver for lan in windows control panel hardware see if it shows the status of the Lan card if its there and working fine then there is problem with the cable u r connecting, or in the TCP IP settings in the Network settings use manual IP address 192.168.0.1 and for other computer 192.168.0.2 if u are connecting 2 computers or what tell me
Posted on Feb 20, 2009
How many pcs can you conect to netgear09 router
Yes you can, connect one of the LAN ports from the router to a LAN hub, Then you have 3 LAN ports on the router and the other LAN ports are on the LAN hub.
Sep 27, 2012 | Computers & Internet
Problem with lan in dell ispiron 6400. When I put in lan wire it shows that cable is not conected. Cable is ok, I tried few. When I look on the conection window sometimes it flashes for less than one...
Inspect the pins inside the network connector. They have to be even and stright. Sometimes people put there a phone cord connector and it bends pins 1, 2, 7 and 8. To recover use a needle with slightly bended tip. Hook the pin with the bended tip and pul until strightened.
Apr 08, 2012 | Dell Inspiron 6400 Notebook
Why Thinkpad T23 2647 4MP can't conect net after installed windows XP?
I do not use an automatic driver detection program, because they have a tendency to install the wrong drivers.
I look in Device Manager, and use the driver that matches THAT device, the O/S used, and is the newest version, (Date), with all the bugs worked out from an older version.
For your laptop that would be;
Ethernet Driver for Intel PRO/100 VE LAN that is the 49675 version, and has the date of November 8, 2002,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS002672
Regards,
joecoolvette
Jan 28, 2012 | IBM ThinkPad T23 2647 Notebook
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
Second monitor not responding
Try conecting everything than restart the laptop, it might detect the monitor automatically.
Jun 01, 2009 | Acer Aspire 3680 Laptop
How to connect usb conection from my data one "UT-300R2U" modem to compaq laptop.we have usb cable and driver cd but drivers are not installed in my laptop.plz give me the complete solution for this...
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
May 12, 2009 | Computers & Internet
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Wireless internet not working contacted perlico and they said that lan port was not open
try pressing start, control panel, network and internet conections, network conections this should show your lan page then press on the lan you need to conect then it should be conect or bridge conections
Nov 04, 2008 | Siemens Computers & Internet
Extra computer connection
conect in your lan cross conection  pc to laptop .then go to network properties then go to network setup wizard & share internet conection note pc name or laptop name both two other name.
Feb 05, 2008 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
