Question about Sharp VC-A410U VCR
Loads then unloads the tape
Tape comes right out when u load it.
    Problem Solver:
  • 8 Answers
Could be a sensor problem. look at bottom side of videotape. in the center towards the top is a round hole, above a screw. then insode the vcr (take top cover off) theres a prism or led sticking up that goes into that hole in the tape, when the tape is loaded. try wrapping masking or electrical tape around it (only a temporary fix)
Posted on Sep 08, 2009
VHS portion not loading or unloading tapes
Yes! it may be the loading basket problem, or the supply voltage is missing.
Mar 09, 2012 | Televison & Video
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
Sony pd 170 not releasing tape,it showing c:32:11error, any sugestion plz....
Loading motor is not functioning so that C:31:11 message flashing.Hope cassette is already in.If you can open camera right side cover unload with 3 volt supply at loading motor.It will work
Mar 18, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I have a tape stuck in upside down.
open the vcr and on the right side you will see the belt and gear that control loading and unloading, with the vcr off and unplugged turn the belt slowly and the tape should work out of the vcr.
Nov 22, 2009 | Televison & Video
BANG AND OLUFSON BEOCORD V8000VIDEO RECORDER TAPE WILL NOT EJECT
turn the motor pulley at the far right corner this is the load/unload motor.unfortuneately the gears in this assy are often the cause for a jammed tape.take to any vcr specialist as the deck is a phillips (turbo) model and well known to engineers.
Apr 15, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
DSR 1500P problems loading tape
Are there any indications on the front panel at all? There should be an error code of some sort there. If not, I'll need to research this a bit. Please update this with any codes.
Thanks,
Dan
Feb 09, 2009 | Sony DSR-1500 Mini DV VCR
Panasonic VCR has F06 code
You appear to have a K Mech model. F06 is the code for the mechanism locking after unload. The cause being something to do with the loading motor or the way the carriage is aligned.
Jan 29, 2009 | Televison & Video
BUSH BTV19SIL NOT LOADING TAPES
There is a small CAM under the foward\reverse takeup wheel. Like a combination lock, must be set in proper sequence to send a signal to eject or load tape. Panasonic VCR has them also.
Hope that this helps, Buddy
P.S. The motor\rubber assembly MUST be set in such a way that the "end of Rubber band line" reaches a certin point WITHOUT turning any more then neccessary because it wll through the switch off aligement.
The LED that the VHS tape covers when it comes down on top of and covers it will give the same problem when it is " caca ".
Feb 07, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
Sharp VC-A410U VCR Logo
104 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
