Bearing in small motor for little fan on heating unit
Central heating (and airconditioner) BDP Company, division of Carrier Corporation Indianapolis, IN. City of Industru, CA Model No. 518A036 Product No. 518AOO036000MAAA Serial No. 4984C48799 This plate is on the cooler part of the 306249-2 059 Central heating and Airconditioner The heating unit has a small motor that moves a small fan. The bearing on the motor is worn too wide. Can I replace the bearing? Can I buy the whole motor? Where? Thank you
I temporally fixed it by disassembling the fan unit and positioning it better.
I need to know where to buy the parts to replace them:
motor, about 3 inches x 3 x 3 very small fan, with blades, diameter = 3 inches inside fan, cylindrical, about 5 inches in diameter, 2 inches deep. Looks like a hamster treadmill This is not a water heater. It is a central heater-air-conditioner
You can't post conmments that contain an email address.
Check line voltage if good then controlle volts that is 24 Ac smell the transformer clean draft hood, burners, fan assembly and filter. Call for heat if nothing check for 24 volts at gas valve if good change thermlocuple. Need more help ask give more info about furnace and what its doing or not doing
If the zone valve was replaced and wired correctly then it is likely the zone controller if u have one. Manually open the valve and turn the tstat up if it begins to circulate then it is a controller issue. If you still get no heat (circulation) than it is the circulator pump or the pumps controller. Its best to test those individual parts with a multimeter to avoid buying parts not needed
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably mechanically inclined: TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem.
Is there a booster motor for the burner? I have seen these stick and make a furnace not turn on. The thermostat trips and you hear the furnace click on but nothing else happens. The booster is a small electric motor connected to a small duct. Take the booster motor loose and turn the fan by hand. Usually they will start working after you do this. Make sure furnace is shut off when you do this. Some booster motors have ports to oil them also.
