My furnace keeps burning wires in the fuse box... right before it does it will kick on and off rapidly.
  • Kent Guidry
    Kent Guidry May 11, 2010
    Lonewolfslad can you tell me if these wires are near the flames?
  • 1,420 Answers
Check the Amp draw of the furnace. May turn out to be a bad blower motor.
Posted on Feb 20, 2009
I have a pilot light but furnace will not kick on,we replace control module but still will not kick on
your positive you have the gas turned on going to this furnas?
also make sure the power going to the furnace is on, it should have a switch with a fuse located close to it and the switch may be off or the fuse is blown out.
if so does the control valve have 2 wires going out to the t-state? if so for a test jumper those wires either at the furnas or at the t-state and see if the furnace turns on, don't forget to remove the jumper as the furnace will not shut off if you don't, this is just to test the wires and or valve.
Sep 27, 2017 | Heating & Cooling
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
How do I shut my furnace off so I can check wiring
The furnace should have an on/off switch...another way to disconnect the power is to remove the fuse(s) at the fuse box...
Jan 28, 2015 | Dryers
Brand new furnace wont start its a aruf 14 electric air handler with a 10 amp heater coil
the 3 amp fuse protects low voltage side of transformer. if it's blowing on a call for cooling wire pair going to outside unit bad or contactor in outside unit.
Nov 18, 2013 | Goodman Heating & Cooling
My thermostat keeps blowing itself out
Electrical problem getting to hot ie burning out stat check transforme rvolts ?
Jan 24, 2013 | Heating & Cooling
Induced draft gas furnace will not turn work
Check the 3-5 amp fuse on the control board of the Furnace, tell me if the fuse has a burn spot on it.
Dec 19, 2012 | Heating & Cooling
Just moved into this house and notice the furnace not working right It is and older unit know name or writing on it I rehooked up wiring to it but now blower run all the time and the only to shut off is...
Older furnaces used to have a fan switch that read winter or summer, or auto and on. You should also have a fused switch to the furnace, wiring runs black to the switch thru the fuse and to the furnace black wire. White wire is straight to furnace from electrical panel. This is for power feed to furnace only. Now the thermostat is red to the transformer white to white. This was a very simple old furnace they had very little safety devises. The fan switch was an older high end model so you could blow the cool air from the basement thru out the whole house in the summer, and the fan ran constantly.
Dec 20, 2010 | Heating & Cooling
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Furnace is not turning on
Sounds like you have a bad fan limit. they will sometimes kick on in the summer when the temp gets high enough. now it sounds like it is not working at all. it is usually mounted with a metal square cover over it removing the cover would expose the dial this it what turns as the furnace heats up and kicks on the fan . turning it by hand will check to see if fan will kick on(turn a lttle clockwise)
Jan 10, 2009 | Heating & Cooling
Kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
Dec 08, 2008 | KitchenAid Dishwashers
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
