Question about Insignia 42" LCD Flat-Panel HDTV
My Vizio vp322 will not power on this morning
Can you help me. My VP322 will not turn on. It worked fine last night, but this morning the orange lighted Vizio logo was not illuminated and the unit will not power up. Please help.
  • Julip Mar 12, 2009
    I have a Vizio vp322 that is having trouble powering on. It cycles through starting and then switching off about a dozen times and, so far, finally comes on. Then it might switch itself off. Thought I'd try to find out the problem before it completely stops powing on, which sounds like might be anytime. Think I'll just leave it on.
  • Devon Sacco
    Devon Sacco May 11, 2010
    Have you check the outlet for power?
    Sergeant:
  • 280 Answers
Probably the power supply has gone bad.. This happens with no warning. Sometimes it is just bad capacitors that have leaked or puffed up in the power board and a good tech can do a cheap fix by replacing them.. Other wise the PS board has to be replaced
Posted on Feb 20, 2009
I have the Vizio vp322 hdtv10a that doesn't turn on,I opened the back panel and found that the capacitors aren't bulging.
Hello, might need a Main Unit or Power Supply by the sounds of it. Try out a company named ShopJimmy.com for parts. I have used them with great success in the past. I included a link to their site from your model page. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=vp322
Sep 06, 2011 | Vizio L32 32 in. LCD HDTV
Power turned on & off by itself then power died completely
Had the same thing. Bad capacitors in power module.
Jan 25, 2010 | Vizio VP322 32 in. Plasma TV
Vizio 32 vp322
Power board is dead.Must be replaced,to get power back.Tries Shopjimmy.com,Ebay.com for the power board part.
Jan 23, 2010 | Vizio VP322 32 in. Plasma TV
I have a vizio vp322 tv and the tv power comess on but no picture the power ligh is all that comes on do know what it might be
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Jan 17, 2010 | Vizio VP322 32 in. Plasma TV
It won't turn on
I replaced 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
Dec 13, 2009 | Vizio VP322 32 in. Plasma TV
I go to turn it on and the vizio label turns white then clicks off
The Vizio VP322 is notorious for having bad capacitors on the power supply circuit board. They will probably be bulging and may have electrolyte leaking. I replaced four bad capacitors (with a different brand just in case) and fixed it. Total cost under $10. A lot cheaper and better than replacing the whole circuit board which may contain the same "faulty" capacitors from the factory.
Nov 12, 2009 | Vizio VP322 32 in. Plasma TV
Vizio vp322 wont do anything but has power
possible main pcb part# 3832-0012-0150
Jun 08, 2009 | Vizio VP322 32 in. Plasma TV
Screen Resolution
You will need to go into your aspect ratio and change the settings(resolution). You probably have your settings set at 4:3
Apr 05, 2009 | Vizio VP322 32 in. Plasma TV
Insignia 42" LCD Flat-Panel HDTV Logo
1,762 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
