Question about Motorola Mobility V710
L7 unable to charge
I voltage in battery connector 1 pin =.67 ,2nd= 2.56,3rd=2.56,4th= gnd
    Novelist:
  • 172 Answers
All cellphone run on Lithium Ion batteries. These batteries, by nature(physics) have a max charged voltage of 3.4 to 4VDC. So, of your charger, or USB cable, has less than about 5 VDC, then either charger is defective, USB cable(if charging from PC USB port) is not a FULL USB(has data leads only wire, 5V power wire not carried through, PC does not supply 5V power to USB because it is turned off by a PC setting option, or a non-powering USB Hub or other device is in series with PC and Phone.
Are you sure you have identified the GND wire correctly? Measurements must all be made with one lead of your VoltMeter referenced to GND. Another consideration, some Windows Mobile phones will not charge off the USB cable unless the latest version of WM ActiveSync or Mobile Device software is loaded and running on the PC. These WM phones also will not charge from just any AC USB generic charger. Charger has to be for that particular phone, or phone manufacture, to be 'recognized' before provideing charge.
The
Posted on Feb 22, 2009
TW10794V-0
If you tell us what the monitor is doing, the solution may not require knowing what voltage is at what pin - especially since some of the voltages may be oscillating!
Dec 12, 2012 | Sharp Computers & Internet
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
P1409
DTC P1409: MEASURE RESISTANCE ACROSS EGR VACUUM REGULATOR SOLENOID
Diagnostic Trouble Code (DTC) P1409 indicates that Self-Test has detected an electrical fault in the EVR circuit.
Possible causes:
Open EVR circuit.
Open VPWR circuit to EGR Vacuum Regulator solenoid.
EVR circuit shorted to VPWR.
EVR circuit shorted to GND.
Damaged EGR Vacuum Regulator solenoid.
Damaged PCM.
Key off.
Disconnect EGR Vacuum Regulator solenoid.
Measure EGR Vacuum Regulator solenoid resistance.
Is solenoid resistance between 26 and 40 ohms?
Yes No
The EGR Vacuum Regulator solenoid resistance is within specification. GO to HE111 . REPLACE EGR Vacuum Regulator solenoid. RECONNECT all components. COMPLETE PCM Reset to clear DTCs. RERUN Quick Test.
HE111 CHECK VPWR CIRCUIT VOLTAGE AT EGR VACUUM REGULATOR SOLENOID
Key on, engine off.
EGR Vacuum Regulator solenoid disconnected.
Measure voltage between VPWR circuit at the EGR Vacuum Regulator solenoid vehicle harness connector and chassis GND.
Is voltage greater than 10.5 volts?
Yes No
GO to HE112 . SERVICE open in VPWR circuit to EGR Vacuum Regulator solenoid. RECONNECT all components. COMPLETE PCM Reset to clear DTCs. RERUN Quick Test.
HE112 CHECK EVR CIRCUIT RESISTANCE
Key off.
Disconnect PCM. Inspect for damaged or pushed out pins, corrosion, loose wires. Service as necessary.
Install breakout box and leave PCM disconnected.
Measure resistance between Test Pin 47 (EVR) and EVR circuit at the EGR Vacuum Regulator solenoid vehicle harness connector.
Is resistance less than 5.0 ohms?
Yes No
GO to HE113 . SERVICE open in EVR circuit. RECONNECT all components. RERUN Quick Test.
HE113 CHECK EVR CIRCUIT FOR SHORTS TO POWER OR GROUND
Key off.
Breakout box installed, leave PCM disconnected.
Measure resistance between Test Pin 47 (EVR) and Test Pins 71 and 97 (VPWR) at the breakout box.
Measure resistance between Test Pin 47 (EVR) and Test Pins 24 and 103 (PWR GND) at the breakout box.
Is each resistance greater than 10,000 ohms?
Yes No
REPLACE damaged PCM. RECONNECT all components. RERUN Quick Test. SERVICE EVR circuit for short to VPWR or PWR GND. RECONNECT all components. RERUN Quick Test.
HE120 CONTINUOUS MEMORY DTC P1409: WIGGLE EGR VACUUM REGULATOR SOLENOID WHILE MONITORING VPWR
Continuous Memory DTC P1409 indicates that Continuous Memory Self-Test has detected an electrical malfunction in the EGR Vacuum Regulator solenoid sometime during vehicle operation.
Note: If DTC P1409 was output in Key On Engine Off (KOEO) or Key On Engine Running (KOER) Self-Test, go to HE110 to diagnose present fault.
Possible causes:
Open EVR circuit.
Damaged PCM.
Install breakout box, leave PCM disconnected.
Measure voltage between Test Pin 47 (EVR) and Test Pins 24 (PWR GND) at the breakout box.
Key on.
Voltage must read greater than 10.5 volts. For an indication of a fault, look for this voltage to drop while performing the following:
Lightly tap on the EGR Vacuum Regulator solenoid.
Wiggle the EGR Vacuum Regulator solenoid connector.
Grasp the EGR Vacuum Regulator solenoid vehicle harness connector and wiggle wires between solenoid and PCM.
Is a fault indicated?
Yes No
ISOLATE fault and SERVICE as necessary. RECONNECT all components. RERUN Quick Test. Unable to duplicate or identify fault at this time. GO to Pinpoint Test Step Z1 with the following data: DPFEGR and EGRVR PIDs and list of possible causes.
Sep 25, 2011 | 2001 Mazda Tribute
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Flashing power light
Check for these power supplies on the Sub deflection board first on the right side of the board there are two Connectors one is a 12 Pin connector CN803 From the top of the connector the wires should read;
30V
Gnd
Gnd
-30V
8.5 V
8.5 V
Gnd
Gnd
-8.5 V
Gnd
Gnd
13.5V
Next is the connector below that one which is a 10 pin connector CN802 they should read
11.7V
11.7V
N.C
Gnd
CTL
Gnd
34V
34V
Gnd
Gnd
Next is a 14 pin connector on the top left side of the board CN801 those should read
34V
34V
Gnd
Gnd
-8.5V
Gnd
8,5V
8.5V
Gnd
13.5
NC
12.5
12.5
Check those supplies and see if they are correct or if any are missing
Mar 09, 2009 | Samsung HCL4715W 47" Rear Projection...
RCA L32WD12 Power Supply
CN3 as follows:
Pin 1 >>> > 12 volts
Pin 2,3, 4 > GND
Pin 5, 6 >> 24 volts
Pin 7 >>>> ON/OFF
CN2 as follows:
Pin 1, 2 >>> GND
Pin 3, 4 >>> 5 VSB (Standby)
Dec 12, 2008 | Televison & Video
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
CTX Panoview 630 Monitor
Panoview 630 Power Connector pinouts:
It has been many years since the question was posted but who knows, maybe this will help someone. Looking at the end of the connector clockwise from 1-oclock position:
1pm:NC
3pm:+12
5pm: no pin
7pm:+5V
9pm:+5V
11pm:GND
shield is GND
+5V@3A
+12V@1.5A
(you can modify an Apple ADB cable to work)
Mar 15, 2007 | CTX Panoview 630 Monitor
Motorola Mobility V710 Logo
114 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
