Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
Once transferred the data to the USB, it shows its correpted.
Iam using Kingston USB 2.0 -32GB
After transfered that data to the USB, it shows the data is correpted, cant open.
My problem is once i transferred the data to the USB Drive, i removed the drive from the system.
Aftr that if i plugged in to any system, i cant use the data.
Ex: If i transferred an image to the USB. and i removed the usb from the system.Again i plugged the USB to the system. If i try to open that image, it will say no preview is available.
If i copy that image to the system also it wont open.
What should i do to solve this issue?
Thanks in advance.
  • 33 Answers
Hi krishnadas06,
Unless you want to copy files that are larger than 4GB you only need to format this drive with FAT32. Do the format and see if that clears it up. You also should be using the "Safely Eject" icon in your task tray prior to unplugging the drive to prevent any possible file corruption.
Kingston Tech Support
Posted on Feb 24, 2009
    Problem Solver:
  • 14 Answers
I recommend that you re-format the drive/device in the system you intend to use it in most.
If you format in the NT mode then your Windows 98 etc will not be able to read the data... this MAY be your problem?
If you are using NT see if it gives you the option to format in 32 bit mode? You MAY be able to use it with both operating systems then.
Hope this helps!
I am using kingston 8gb pendrive it is taking half an hour to copy 600mb of data.how it can be improved?please give me suggestions......
Your computer may have both "USB 1.1" and "USB 2.0" ports.
The speed of data-transfer through a USB 2.0 port is at least 5 times faster than through a USB 1.1 port.
So, connect your USB memory-stick to a USB 2.0 port.
Oct 21, 2010 | Computers & Internet
Acer Aspire M5100: Won't transfer Files/Data to larger USB Drives
It's a Vista compatability issue,This is very common and they should have some kind a patch for it soon. Here is a link to read for more details and data recovery options.
Please take time to rate this fixya.
May 16, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Files in my kingston pendrive does not open up
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
May 03, 2009 | Kingston 4GB Secure Digital High Capacity...
8GB Kingston Data Traveller only has 101mb available!
Hi Cristina,
This is Azeem Inam. your data traveller does not accept data over 101MBs. There can be two reasons for this problem. 1. there may be a virus that has provided a limitation on the copying facility. 2. This can be a partition problem. All you need to do is to use the software called DM (Disk manager). This is a DOS versioned software. Go into its advance installation option and then accept the hard disk kingston data traveller. It will take you to another menu showing the partition styles you may choose. you'll have to choose FAT32 type. then in the next menu you'll have to choose partition size by pressing enter button. and then accepting format you are done. it will start working as new again. Thanks for consulting your problem.
Feb 13, 2009 | Kingston Technologies 512MB DataTraveler I...
2GB KINGSTON DATA TRAVELLER
try using format through windows or go to the provider site and use their utilities,
Nov 24, 2008 | Computers & Internet
Usb stick
Hi travlyn,
If you are using Windows XP or Windows Vista, you just need to plug it into a free USB port on your laptop or desktop computer. The OS will automatically find the hardware, then install it. A popup will show up asking what you want to do. You can select there open the folder to open up the contents of the drive. Otherwise you can just close this up and just goto MY COMPUTER and access the USB stick from there.
The USB drive should be ready to receive data, you can actually drag or drop files into it or copy paste the items into the drive. Or if you are making documents or spreadsheets you can directly use the drive to save files.
It's very easy, you should try it out once you're in front of your computer.
Hope this helps!
Peace! :)
Oct 21, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston USB 4GB
sounds like a bad hard disk or a malware virus interceptiong all data and corrupting it.
try www.hdtune.com free home version. if in health tab shows yellow. start looking for a hard disk
try in start, run (type) chkdsk /f black windows shows. press Y then enter reboot. see if it finds corruption. if its data not physical damage, it might fix it!
for virus malware issues i usualy head to majorgeeks.com for top 10 dloads and forum help.
Oct 05, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb software
be sure you have Microsoft ActiveSync installed: http://www.microsoft.com/windowsmobile/en-us/help/synchronize/default.mspx
once this is installed, then connect you phone and follow the steps to sync. Once connected, you should be able to browse the contents of your phone from My Computer (copy and paste files or whatever).
Jun 11, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Kingston DTI/2GBFE
I can offer a suggestion or two. In order to tell if the problem is the flash drive or the computer, try attaching it to a different computer, and test it with similar file transfers.
If it behaves the same, then it is probably faulty. There's only a slight chance that running a Check Disk on it will improve things. (in My Computer, Right-Click on the flash drive, then click on Properties, then the Tools tab, then the Check Now button).
If it seems fine on a different computer, then try attaching it to your own computer on different USB ports. In particular, do not attach to a USB hub, but directly to a front or back port. If you are successful in finding a good port, then consider the previously used USB port to be faulty.
Dec 04, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
98 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
