Question about HP Pavilion a1010n (PS563AA) PC Desktop
Computer turns on then immediately shuts down
The problem started right after I moved the computer from my office to my home. The power circut is good and has been tested by another computer,
Thanks
A person posted a possible solution on your site. He said, " remove the ram and then hold the on buttton while plugging in the computer." It worked, so I shut the machine down restarted in safe mode, checked everything then did a security scan. Everything was ok. I shut the machine down, removed the front cover, removed the switch cover plate and vacuumed out all the fuzzys .....
I think the real problem was a dirty switch ..... anyhow thanks for the site and the person who sent in a possible solution.
RA
Posted on Feb 23, 2009
    President:
  • 1,223 Answers
Check Ram first try changing it other wise ur Mother board is giving fault try ram first try re installing it , check the power as well
Posted on Feb 20, 2009
Can't logon to my acer laptop it says the following, the user profile service failed the logon user profile cannot be loaded
Shut down your computer. To do a hard shutdown hold the power button down until it turns off. You probably need it to go to last known good configuration. To to this 1. find the F8 key (keep finger on it(not pushed yet). 2. Turn Power button on and immediately start tapping F8 key. This will take you to a screen with many options; Last Known Good Configuration is one of them. It should start up. Hope this helps.
Apr 27, 2013 | Acer Computers & Internet
I have a Gigabyte EX38 DS4 motherboard. A few months ago the power light light would blink after I shut windows down and it wouldn't turn on again. If I unplugged the computer for a while it would stop...
As you may already know, your computer will shut down after power on if if the power supply does not receive a power good signal from the motherboard. Since you already tested the PSU in another computer, and you know the PSU is good, either you have a bad mobo or some device connected to the power supply is draining excessive power from the PSU and causing it to shut down.
Try removing the 4 pin pin power plugs from ALL devices, such as the floppy drive, CD drives etc.
If the system stays on when you power up, then you can isolate the faulty device by re-connecting them one-by-one. If the system still shuts down your Mobo or CPU is bad and you might want to take it to a PC technician to determine if it's worth fixing.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 18, 2011 | Intel Motherboard
HP Officejet J4680 Was connected to home wireless network for 8 months. Now won't connect. Tried everything. Router works perfectly with all computers & internet.
Shut down all computers and another devices connected to network. Shut down Router. Wait 3 minutes. Power on Router. Wait. Power on all devices.
Nov 07, 2010 | HP J4680 Office Jet All-In-One Printer
I have a compaq computer that works great for 1 hour the shuts do
Is it shuting down? Or just instantly going off.
If it is shutting down, adjust the power settings.
  • Control Panel
  • Power Options
  • Make sure the scheme you want is selected. For a desktop it should be Home/Office or Always on.
  • Make sure that System Standby and Hibernate (if available) are set to the length you want.
Mar 13, 2010 | Compaq Presario 5000 PC Desktop
Electical stalls out while driving
I HAD THIS SAME PROBLUM AND IT WAS THE OXIGIN CENSER MIGHT WONT TO TRI THAT ??
Mar 26, 2009 | 1991 Dodge Dakota
Remote access to dial-up connected computer
https://secure.logmein.com/home.asp?lang=en
Try this.Set it like after reboot it automatically starts.
Once it comes up you will be able to connect again.
Please rate me if you like my solution.
Mar 12, 2009 | Microsoft Windows XP Professional Upgrade...
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
Computer will not shut down
right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Jan 27, 2009 | Computers & Internet
HP Pavilion a1010n won't start
Make sure there is no dust covering the computer fan. If necessary use the recovery CD or a new Windows XP CD.
Jul 29, 2008 | HP Pavilion a1010n (PS563AA) PC Desktop
I have a Pan. pt 51g30t shuts off immediately
The most likely part is a fault with the convergence board and the main power supply. In many sets like yours when an amp module on the convergence fails the picture will bend out of shape and cause the power supply to shut down
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Panasonic PT-51G44 51" Rear Projection...
HP Pavilion a1010n (PS563AA) PC Desktop Logo
163 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
