Question about Konica Minolta magicolor 2400 Laser Printer
Paper got stuck in Konica Milolta magicolor 2400w
When printing, a piece of paper got stuck in the feeder at the top - I pulled the paper out and it ripped and I can't get to the paper in the back. Is there anyway to take this thing apart to get that paper out?
  • Anonymous Feb 24, 2009
    Same problem here! I'd hate to buy a new printer because of a paper jam but I can't figure out a way to get to the jam. Anyone???
I had the same problem and this worked, although it is not the answer to your question:
Take a standard manila file folder and cut it to the basic shape of a standard piece of paper. When you lift the top cover on the under side you will see a diagram on how to pull the paper out in the case of a paper jam. Feed you file folder up from the bottom and you will ~ with a little work, more than likely be able to clear the jam.
Posted on Mar 02, 2009
Text is printing too low on the page
I have a Magicolor 2400w and had the same problem... I hope I'm not to late because I almost put mine in the trash.
How I fixed the problem was I adjusted the solenoid behind the fan on the right side. I made a video and posted is on YouTube. Search YouTube for Magicolor 2400w paper size error. or follow the link.
http://www.youtube.com/watch?v=jlyuPJW6RjU
Hope this helps
Dec 29, 2012 | Konica Minolta magicolor 2400 Laser...
Konica Minolta 2400w paper jam at top back side. Several small pieces stuck and I can't reach them. Is there a way to disasemble?
yes there is a way, but if you do it yourself there are more chances that you will break it.so dont try it yourself.call concerning technical service rep.
Jun 10, 2010 | Konica Minolta magicolor 2400 Laser...
I just install a konica minolta magicolor 2400w printer on a computer thats running vista. Everything seems to be installed correctly but when I go to print something, it would not print, the ready light...
I have a Konica user guide for your printer here:
2400w User guide PDF
Have a look at the introduction and troubleshoot sections for the light blink codes, these give you an idea if it could be an error.
May 14, 2010 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
I have a 2400w with a paper jam in the rear of the machine, how do I go about removing it?
Try to pull it down, from the inside of the machine. If it is not taken out in one piece, you need to call a tech.
Jun 29, 2009 | Konica Minolta magicolor 2400 Laser...
BADLY IN NEED OF PURCHASING A GENUINE FUSER FOR MYMINOLTA 2400W AS THE LASER PRINT INK WONT FUSE TO THE PAPER. CAN YOU HELP
A search on Google for "konica 2400w fuser" turned up a few sources. Here is one I picked as an example. You can try searching based on the manufacturer's part number as well, as that may come up with additional sources and prices. Good luck with your search!
May 01, 2009 | Konica Minolta magicolor 2400 Laser...
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Paper keeps jaming!
Print a test page, then when it jams, notice if the paper made it's way in to fuser (toward the back of the unit. If it got that far, your fuser may be bad.
Let me know.
Nov 22, 2008 | Minolta magicolor 2400W Laser Printer
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
288 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
