Question about Denon AVR-1803 Receiver
Power button won't shut off
My receiver power button wouldn't turn on last night, the little red stand by botton was on. It is connected to a power strip, so I turned it off and then back on-The receiver came on but now when you push the botton to turn it off-it won't go off-Any suggestions???? I turned the amp off to tighten the centre channel speaker leads. Tilting the unit over turned the power button ON and I caused a 'sparkie' from the positive terminal to the chassis. The two internal fuses are still intact but all I can get is the little red led on turn on. I cant get the unit to operate. After 24 hours it is still the same. I can detect no 'smokies' anywhere inside and there is no smell at all..
    President:
  • 1,952 Answers
Fuse is off then fix the fuse and change the powerbutton then not start you will change the powerboard
Posted on Feb 20, 2009
  • mohammed marika thambi
    mohammed marika thambi Feb 20, 2009
    These units have Protection circuits for Overcurrent, Dc Protect, 15v
    Regulator inbalance, Rail Voltage Inbalance, Low Ac Voltage, Low
    Standby Voltage and Thermal Protection just to name the ones I
    remember. My guess is you Probably have either Poor Intermittent solder
    connections or Amp is not Ventillating Properly. Make sure you leave
    room above Receiver to Vent and You are using no Less then 6 ohm
    speaker Impedance per ch. Refer to Speaker Impedance chart on back
    panel .
    Look in the Owners manual for a Reinitialize procedure , Restores
    everything to Factory defaults. Usually consists of Holding a couple
    switches while turning on main power. All Lights Should light up to
    verify Initialization. Then setup unit like you just bought it.
What if the tv is off and the red stand by light is not on what does that mean
The red "stand by" light shows power is getting to the TV. If it is off, you may have no house power being connected. If you can get the red light to come on but your TV still does not turn on the power supply may have failed
Apr 04, 2013 | Sylvania Televison & Video
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Dead no power.. checked main fuse, worked fine last night, went to turn it on today and nothing. its a sx-316 not sx-315, I say this because it tells me this is not a valid model#, but sx316 is printed on...
Check the resistance of the primary on the main power transformer, (with power off) should be 1-3 ohms. If open you need a new transformer.
If good turn it on and check for ac voltage (120v) there.
Nov 26, 2009 | Pioneer SX-315
Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Dec 14, 2008 | Denon AVR-1908
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
Receiver makes clicking sound when I push power, but does not turn on.
Sounds like a fualty push button - try connecting/soldering on a new one of a different type!
Jul 04, 2008 | Audio Players & Recorders
First thing to do is unplug the reciver for 12 to 24 hours. Sounds like it needs to be reset.
Sep 18, 2006 | Denon AVR-1803 Receiver
Denon AVR-1803 Receiver Logo
65 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
