Question about Ovens
Need to know wiring for element
I need to know what colour wire goes to which pin on a westinghouse element with six prongs. (Power element). colours are two blacks two blues red and white.
I removed the wires from the fan and element and cant remember which colour wire goes where is thir a pictures for baumatie oven that i can use as a guide
Posted on Oct 19, 2011
Fitting new top element
I take it you didn't note where they went before? The web is full of handbooks spare part diagrams etc. Various F & P sites as well. Have a dig around for your model. Which you didn't tell us by the way??
Mar 30, 2015 | Fisher and Paykel Ovens
Hi, I have a Neff Double Oven (U1721N0GB/02). In the process of replacing the main oven element (which was clearly visibly faulty) I think I may have casued a short-sircuit / blown an in-line fuse. I have...
Did you replace the element from inside the oven cavity? If so, you may have knock off one of the spade connections whilst pulling the bracket through. Isolate from mains, remove back panel behind oven (not in the cavity) and check you don't have a wire floating about. The wires usually look quite similar but if you look closing they should have a black or red fleck in them, the element has two prongs on each side, you need to put the two the same colour on one side and the other single different colour on the other prong. If the fan is working then you have not blown the limiter that you will see quite close to the fan, but you might have blown the thermostat or the selector switch. If the red light comes on the fascia when you select the temp then it's pretty safe to assume the thermostat is ok. Hope this helps
Mar 24, 2013 | Neff U1721 Double circotherm Electric Oven
I have removed the element from my technika fan forced wall oven. Not sure which wire is the earth ? There are 3 wires. onehas two wires running to the terminal clip and the other two are single...
Simple the colour of the wire will give you the direction of their function what you need to know are the color of the wire.
However, if there is red wire among the two wires or( white or yellow) the white means and the red means power.
Good luck and then make sure that all electric power are disconnected .
Thanks for using fixya.
Jul 30, 2011 | Ovens
I've plulled the element out and the connectors have come off not sure which colour goes on which connection. also there are two prongs on each connector and only one clip for each side?
john,
it dosn't matter what colour goes where as such. just make sure the earth wire ( if there is one), usually green and yellow in colour goes in the middle. otherwise as long as live and neutral connected in any order it will work.
also there may be two prongs but if you look closely they are really as one.
Jul 11, 2011 | Ovens
Can you tell me where the wires go on electric cooker the colours are blue,copper,brown done know which wire goes where ,to the left middle, right
When you say electric cooker are you talking about an element or the whole oven unit. I can help but need more details.
Mar 02, 2011 | Ovens
Have bought a westinghouse cooktop and the wires are a different colour to my old simpson cooktop, can you tell me which wires from my wall go where on there westinghouse, i have a green/yellow which i...
Is it a Green wire with Yellow strips that would be the ground or (earth) would go on the round plug or the center wire if you have a flat cord. The Red can be L1 or L2 The Black can be which ever one is left over L1 or L2 Both the Black and Red wires will be HOT to make up 240 Volts.
Feb 05, 2011 | Ovens
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
Leisure rangemaster 110 fan oven element replaced but still does not get hot
There are 3 possibilities:
Faulty thermostat
Faulty wiring
Faulty oven control switch
Thermostats fail more often in the closed position which means your oven will overheat so I'd test the wiring first. You'll need an Ohm meter to do this. TURN THE POWER OFF FIRST, expose the element and switch then trace the wires from the live and neutral terminals on the element back to the switch. If you can't trace them, make a note of their colours (at the element end) and test for continuity/resistance with wires of the same diameter and colour at the switch. You should get a reading of zero ohms if you have good continuity.
The easiest way to check the switch is visually. Make a note of the wiring colours and their positions on the switch terminals, disconnect them and remove the switch. See if anything looks broken or the
Some thermostats can be disassembled and inspected, but I don't recommend it unless you know what you're doing. The gap between the thermostat switch contacts needs to be precise or the oven wont heat to the correct temperate.
If you can establish that the wiring and switch are OK, try replacing the thermostat.
Oct 15, 2010 | Ovens
What wire goes where for my Westinghouse Freestyle elements?
oven wiring has the same conventions as house wiring.
green = earth, outside coating
brown or white = one of core ends
black = the other end
Jul 13, 2008 | Ovens
Ovens Logo
237 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
