Question about Konica Minolta Office Equipment & Supplies
Copier konica 7035 call service f-35-4
I just want to know how can i fix my copier with this error and what is the possible cause of this?i just replace the toner with new one and when i switch the copier on the call service f-35-4 appears on the screen..can someone help me to solve my problem?tnx in advance..
  • 26 Answers
CAUSE: Incorrect AC wiring connections on the 4-pin fasten terminal block located in the rear of the fuser unit.
SOLUTION: Reconnect the AC wiring to the 4-pin fasten terminal block as follows:
While viewing the 4-pin fasten terminal block from the rear of the fuser:
RED wire from top lamp (L2), in the heat roller, is connected to the right front terminal.
BLACK wire from the bottom lamp (L3), in the heat roller, is connected to the left front terminal.
WHITE wire from the top rear position (closest to the web) of the main fuser connector CN13 is connected to the left rear terminal.
WHITE wire from the top front position of the main fuser connector CN13 is connected to the right rear terminal.
Posted on Feb 21, 2009
F-35-4 ???
Posted on Jun 08, 2009
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
Our non-profit was donated a Konica 7035 multi-function copier that says on the display that it has a printer board problem. We can we find one, what's the cost, and is it worth fixing?
Hello.
If the problem is with the printer drive board, the copier needs to be serviced.
Depending on the cost of repair, it may not be worth fixing.
If the copier was just donated, is it possible to contact the donor to see if they had priced out the cost, since I suspect that they were experiencing problems as well.
Hope this helps.
Mar 05, 2010 | Office Equipment & Supplies
Konica coppier 7035 (F-26-1 error)
Since im from Phil. =) F-26-1 mean Developing problem. Check if theres enough developer (black powder) coz sometimes it spills if ok, Go to TECH. REP. MODE screen and press ATDC ADJ. wait for 2 mins. it automatically stop it will indicate OK. Turn Off the power and On.
Jan 17, 2010 | Konica 7075 All-In-One Laser Printer
I have a Konica 7035 that has code F-35-6 show up. We found a major paper jam, removed it after taking apart part of the copier but the code remains. Any advise? Also, where can I find a manual for this...
Hello sir; Here is the way to reset this error code; press and hold down 25 while you turn on the machine, chose 1 for software switch, use up/down key to select dipswitch 3, and bit 1, then change 1 to 0 by pressing ''off".
Jan 10, 2010 | Konica Minolta DiALTA Di200 Copier
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Konica Minolta Copiers
F26 Toner density adjustment problem. This means machine is undertoned. To repair, replace developer and enter "47" mode. Press 51. Press print. Allow the machine to cycle until it stops. Some feel that you should disconnect the toner motor first. This ??? ?????? happens probably because either machine wasn't set up properly, or the customer kept on using the machine with the toner light on.
Aug 22, 2008 | Konica Minolta Office Equipment & Supplies
Error F-35-4
problem konica F-35-4
Oct 15, 2007 | Office Equipment & Supplies
527 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
