Question about ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
Will i have to increase my fan speed????? - ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
  • ASUS Master
  • 13,433 Answers
Hey,
The fan speed of the video card is controller by the bios on the card or by the driver used by windows.
You can try asus smartdoctor and see if you can adjust it on that.
but looking at the picture of the product you have selected, it would seem this one has a passive cooler, no fan.
But have a look at Asus SmartDoctor and see if that fits your need. http://www.asus.com/999/html/share/2/icon/11/index.htm
Thanks,
Ekse
Posted on Feb 20, 2009
Have problem with ac it works on fan positions 1&2 but when you increase the fan speed the fan speed increases but cuts out the Ac any thoughts please
It could be any car your very vague but most blower motors have a relay and when it fails you loose other speeds
Nov 06, 2016 | AC Cars & Trucks
Ex110 increases fan speed
Think this may just be coincidence, make sure the pc is nice and clean inside and is getting good air flow. Also check that any other fans using the psu or the motherboard are spinning. One may be compensating another that has failed.
Nov 21, 2013 | Logitech Computers & Internet
I have an 85 corvette. the problem is the air conditioning. I have it on high speed but the air blows out very little like if its on low speed. and the compressor and evaporator is new so what could it be...
If your car has a cabin filter (check owners/service manual) it may be clogged.
You may also have a vacuum leak under the dash causing the vent flaps to not open all the way.
Jun 09, 2011 | 1985 Chevrolet Corvette
Whenever I turned on the air condition in my Ford Explorer 2006, after few second the radiator Fan start running very frequently on high speed making noise. When the fan starts on high the rpm of the...
The cooling fan is supposed to come on when the /ac compressor clutch cycles on, and off when it cycles off.
The idle speed kicks up to compensate for the additional a/c compressor load and the additional alternator load. usually, just the low speed comes on until it hits a much higher temperature.
the system should cycle 4 to 7 times/minute at 79 degrees F.
Here are some things to consider:(The PCM (engine computer) is NEVER defective, don't replace it). I don't think it is the ECT (engine coolant temp sensor) or the Cylinder Head Temp Sensor. Or the VSS or the MAF sensors.
The electronically controlled fan clutch is controlled by the powertrain control module (PCM) based upon requests for airflow to cool the engine, transmission and A/C condenser. If no cooling is required, the electronics permit the fan to spin at a slower speed yielding improved fuel economy.
Inoperative or damaged:
  • Electronically actuated fan clutch
  • Electronically actuated fan clutch controller
  • Wiring, connectors, relays or modules
  • Engine Coolant Temperature (ECT) sensor (4.0L SOHC)
  • Cylinder Head Temperature (CHT) sensor (4.6L [3V])
  • Mass Air Flow (MAF) sensor
  • Vehicle Speed Sensor (VSS)
If the cause is not visually evident, connect the scan tool to the Data Link Connector (DLC).
Retrieve any DTC Codes (Diagnostic Test Code). Autozone will do for free.
The cooling fan clutch actuator valve controls the fluid flow from the reservoir into the working chamber. Once viscous fluid is in the working chamber, shearing of the fluid results in fan rotation.
The cooling fan clutch actuator valve is activated with a pulse width modulated (PWM) output signal from the powertrain control module (PCM). By opening and closing the fluid port valve, the PCM can control the cooling fan clutch speed. The cooling fan clutch speed is measured by a Hall-effect sensor and is monitored by the PCM during closed loop operation.
The PCM optimizes fan speed based on engine coolant temperature (ECT), engine oil temperature (EOT), transmission fluid temperature (TFT), intake air temperature (IAT), or air conditioning requirements. When an increased demand for fan speed is requested for vehicle cooling, the PCM monitors the fan speed through the Hall-effect sensor. If a fan speed increase is required, the PCM outputs the PWM signal to the fluid port, providing the required fan speed increase.
May 20, 2011 | 2006 Ford Explorer
Fan speed does not increase while cpu temperature is far too high
Hello
The fan speed is automatic, when it need to increase it will done by itself, if fan is OK then there is no need to worry. Good Luck
Feb 15, 2011 | Compaq Presario 700 470024-192 Notebook
Air conditioner goes off when fan speed is increased
when it's on 'auto', the fan adjusts according to the temp in the car and the temp setting you have it set at. try setting the auto temp control down to 65, then hit the "-" one more time to send it to "LO" - the fan should automatically jump up to max.
Jul 01, 2010 | 2001 Audi A4
Latitude e6500 runs hot how do i boost the fan
You may need to clean the fan and heatsink of dust. See the dust restricts the cool air from reaching the heatsink and this in turn causes your fan to spin faster. The computer's BIOS is programmed to increase CPU fan speed as CPU tempreature increases. If your fan is very loud, then it is running at the maximum speed possible. A clean heatsink will decrease the Processor's temperature.
Installing additional fans in your computer's chassis is an effective way of bringing the temperatures down. Install the biggest fans that your chassis supports. 120mm fans are better than 80mm fans as they can spin at slower speeds to provide the same airflow of a smaller fan. Therefore giving you a quiet computer.
Use a program called Speed Fan to ensure that your fans are indeed running at the desirable level of 100%
Take care!
damnor01
May 12, 2010 | Dell (6F858) Cooling Fan
2003 Chev Malibu.V6, loaded: HVAC: control head
under the dash on the right side ,look for a plug with 5 wires . That switch is called a RHEOSTAT.(fan speed control).Sounds like it is defective
Apr 05, 2010 | 2003 Chevrolet Malibu
Overclock fan speed question
The amount that you can overclock you're video card differes for each individual card. The limiting factors are temperatures and stability. If games start crashing, etc you should back off the overclocking. Also keep in mind the temperature of the card. Increasing fan speeds will lower the temperatures of the card. Increasing the fan speed (as long as you don't go beyond 100%) will not damage the card... It will be louder though. For the 9800gt, the maximum temperature before damage is 105 degrees C. Try to keep the temperatures at 80 or below optimally. Increasing the fan speed is the best way to accomplish this.
Jan 17, 2010 | Nvidia Zotac GeForce 9800GT Amp Edition...
Fan problem
No sorry. Fans can be monitored through the bios & even set to give you an alarm when the speed gets too low but you can not increase the fan speed. You can replace it with a faster rpm fan.
Standard cpu fans run between 3100rpm to 6000rpm. It is up too you. Some creat a wee bit too much noise after 4000rpm.
Heres a few for your Intel Socket 775 Pentium 4.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1588&Nav=|c:493|&Sort=0&Recs=10
Please vote!
Jan 13, 2008 | Jetway (V2MDMP) Motherboard
ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
