Question about Valet 561T Remote Start Module
94 crown vic remote start??
I just bought a valet 161r remote start system for a 94 crown vic. i got it because it was $24 from $149 at the liquidation sale at circuit city. i dont plan on installing it myself cuz there is way too much to install. if i dont have a currrent alarm will this still work for at least remote start my car? i dont have even a basic alarm with horn or none of that. just want to know wat parts or if anything else i would need to purchase to like i said at least remote start the car. thank you
  • 95 Answers
You will not need anything else. If your not planning on doing it yourself than you will need to bring it to a shop to have it put in. This car is pretty system install. You can obtain a wiring diagram for it and put it in yourself. But if not you will not need anything else for this vehicle
Posted on Feb 20, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
'94 Avalon. Why won't it turn over?
There isn't a valet switch but you should have a second valet key. That is designed to allow the car to be started and run but will not unlock the trunk or glove box. See if you have a key that is similar but not the same as the other main key and see if you can start it with that. If you have an remote alarm system, that could be interfering with starting. See if you can override the alarm.
May 27, 2015 | Toyota Cars & Trucks
How often should i replace timing chains on a 03 crown vic with the 4.6L, or should i not worry about it if no noise is preset at all? i just bought a 03 crown vic with 218,*** miles, engine has no no
if there is no chain noise now there is a good chance that the chain has been replaced
the engine is around the mileage when a chain would be getting a bit noisy
you can monitor for noise or replace the chain anyway But I am from from the old school--if it ain't broke don't fix it ---
Sep 11, 2014 | Nike Timing Triax V10 Watch
How do I replace battery in remote for 1999 Crown Vic
Remote needs to be taken apart either by a small screwdriver, or by finding the small tabs on the side and separating the two halves of the remote. Button cell batteries.
Nov 22, 2017 | 1999 Ford Crown Victoria
How to change timing belt on 94 crown vic
No timing belts on a 94 Vic. It's timing chains and it's not easy.You'll need a manual and some skill. Good tools, too. don-ohio
Sep 09, 2011 | Ford Crown Victoria Cars & Trucks
Can I bleed my 94 Crown Vic brakes with out special equipment? I have bled several older brake systems on my vehicles without ABS systems in the past. Thanks Jim
I have done the brakes many times on my own 1994 Vic and never had a problem. Just start at the farthest brake in back and work your way forward. The drivers side front is the shortest line. If you do have any problems, I use a Vacuum handheld bleeder pump.
They make it nice because the 4 ounce cup that comes with it holds enough discharged fluid that you get very little spill, if any at all. You can gravity bleed them too.
Nov 06, 2010 | 1994 Ford Crown Victoria
Lost Transmitter
I had a remote that didn't work and I found the 561r complete remote start system on ebay for $32.00 including shipping so I bought that and within 2 minutes had the new remote programed and now I have the main unit in case mine goes out also.
May 16, 2010 | Directed Dei Valet 561r Remote...
94 crown vic how do i find out if car has keyless entry
Easy. Does your Vic have a five number keypad above the driver's side exterior door handle? If so the you got key-less. If not, you do not.
Jun 13, 2009 | 1994 Ford Crown Victoria
'94 Ford Crown Vic Headlights
They are changed from within the engine compartment... at the rear of the headlight bazels... if it's the side on the battery you may have to remove it.... also don't touch the bulbs with your fingers as that shortens the life of them.
Robert
Jan 17, 2009 | 1994 Ford Crown Victoria
Lost keyless remote
take it to a local dodge dealer or a stereo store and they could tell u how to disable the alarm
Nov 29, 2008 | 1994 Dodge Intrepid
Valet 561T Remote Start Module Logo
167 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
