Question about KitchenAid Architect Series KSRP22FSSS 33" Superba Side-By-Side Refrigerator w/ 21.7 Cu. Ft. Capacit...
I have an older style kitchenaid refrigerator with french doors on the rightside under the meat storage locker a block of ice forms then melts leaking everwhere (any suggestions)
    Problem Solver:
  • 17 Answers
There should be small defrost heater located on the coil, that turns on when the compressor turns off to stop ice building up. sounds like that is faulty.
Posted on Feb 20, 2009
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
How do i prevent ice cubes from freezing in the bin
It is happening because the air getting into refrigerator through the small gap between the door so please
Change the refrigerator's rubber seal
Jul 26, 2014 | KitchenAid Refrigerators
Water forms under meat bin
Stop buying meat! Human are not meant to ever eat meat. You are a vegan by design.
Feb 15, 2014 | LG LRFD25850 French Door Refrigerator
Ice maker not dropping ice
Need more info. Are there ice cubes in the storage section just behind the freezer door? You may have turned the ice-maker OFF. When your depress the ice flipper, does the motor run behind the door? The motor may be burned out or the ice cubes in the storage section are so melted together in a giant glob that the agitator cannot turn.Or, maybe someone turned OFF the water supply.
Aug 10, 2012 | Samsung RF4267HARS Stainless Steel French...
Ice forming in the bottom of the freezer. eventually melting and ending with water running on the floor from both corners of freezer
Check the seal on the door and make sure it is "sound". Pay particular attention to the bottom or underside of the freezer door / drawer. Make sure nothing is preventing a seal between the fridge case and door. Misfigured, distorted or otherwise damaged seals can cause frost build up as you describe. Clear any objects / replace damaged seals found.
Sep 06, 2011 | KitchenAid KBFS25EVMS Stainless Steel...
The freezer is forming ice on back wall and all around the ice bins where the ice storage is, plus forming on food boxes, what could be the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Kenmore TRIO 77314 Side by Side Bottom...
What do do when our KitchenAid ice storage bin is stuck and hard to get out?
if the ice bucket that holds your ice is on the door simple leave the door open for a 15 to 20 minutes and it should melt free if the ice bin is in the freezer the same should work but it may take a little longer
Apr 03, 2010 | KitchenAid KSRG25FK Side by Side...
Water is not cooling
Hi: This Wide by side is like all other side by sides as to how it stores the water. Storage will be behind the crisper or meat keeper in the form of a coil of tubing or a bladder to store the water. Pretty simple. The length of tubing running from the storage to the dispenser will not be chilled. Some refrigerators do this better than others. Try setting the ref. or meat keeper a little colder. Watch your vegetables so they don't freeze. Rare, but it's possible... Older homes (before dispensers,) when fridges just had ice makers, would tap into the hot water line for ice to freeze faster and be clearer. I know this sounds crazy but it's true. I lived in an older home and in the winter the hot water would always freeze first. I know this solution sounds lame but there really is nothing much to go wrong with the water chilling. Pull your meat keeper out and look at the reservoir and see how cold it is. Good luck, Jeff
Jun 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
KitchenAid Architect Series KSRP22FSSS 33" Superba Side-By-Side Refrigerator w/ 21.7 Cu. Ft. Capacit... Logo
123 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
